My Poor Wee Mini Sky
#136
Posted 10 March 2011 - 09:38 PM
#137
Posted 10 March 2011 - 09:47 PM
#138
Posted 11 March 2011 - 09:54 AM
#139
Posted 11 March 2011 - 10:04 PM
Graham
#140
Posted 13 March 2011 - 02:08 PM
I'm yet to own a mini, hoping to pick one up the end of this summer or after Uni in a year, I'd love a project but I'm terrified of welding and grinding having never done it, after reading through this thread I'm starting to think that everything can be picked up with enough time.
You're doing an ace job, it's amazing how far you've come in such a short time, definitely keep going and take as many pictures as you can!
#141
Posted 29 March 2011 - 08:41 PM
Thanks Carlos and iDemonix for the kind words - maybe too hasty! The welding is terrifying and I don't know enough. But if you don't try you don't learn and you do learn by your mistakes. Well I hope I do.
I eventually got the grinder out and persuaded the windscreen to fit. I'm not happy with it but time will allow the memory of how bad it is to fade.
And with the bonnet - there is a slight unevenness, hence my son's scooter battery keeping one side down
All I have done since then is fit the under-scuttle closing panels
If I can offer any advice to anyone fitting the windscreen surround panel -
1. If it doesn't fit to the old aperture - force the old metal out to join with the new - not force the new to the old.
2. Plug weld along the underside of the top where it meets the roof, even though upside down welding is difficult.
3. Don't remove the stiffener in the middle of the aperture till it is all welded in - it keeps the distance apart constant.
4. Maybe - don't do it at all - avoid the stress - it's an expensive panel!!
Well I have some new panels arriving - front floors and sills. I do have wings, front panel and Apex panels up in the attic but am going to do them after the underside is repaired, the subframes tidied and back on its wheels.
Not grinding along
Hugh
#142
Posted 29 March 2011 - 09:25 PM
Oh to be a wise person, and still a novice at this myself !!
sorry it was a trial to get it to fit but fit it did in the end and that is the importnt bit, looks good from here too !! I too find the welding scary, I haven't tried my OS door yet as no hinges so don't know if my welding is ok yet, very scary till I can test, so I know exactly how you feel !!
Nice job on the scuttle closing plates, a job I have comming up. Did you weld to the outer side of the scuttle, plugs look ace but can't see anything else ??
Graham
ps, home made or pattern closers??
pps Give the bonnet a twist, usually sorts out the ill fitting if only the bonnet kinked, worked for me !!
Edited by grahama, 29 March 2011 - 09:29 PM.
#143
Posted 30 March 2011 - 08:43 PM
Kind wishes - Hugh
#144
Posted 18 April 2011 - 07:28 PM
#145
Posted 18 April 2011 - 07:57 PM
Its looking really good and before you know it it will be time for paint which will be the next hurdle.
#146
Posted 18 April 2011 - 11:43 PM
Always love it when I get an email saying this is updated.
Matt
#147
Posted 19 April 2011 - 05:47 PM
A big thanks for the surprise comments when I opened my topic to update. I thought it would be well forgotten. Thanks Matt, Neil and iDemonix.
I decided to replace part of the driver's side floor.
To fit this
So I cut out a big hole
And did a grotty little repair - need to get the welding going again!!
And trial fitted the cut panel. It is not a great fit but will use Neil's recommended tool - a hammer.
This takes five seconds to explain but it is five hours work.
Well at least I'm moving again. Should get it welded in tomorrow. I can't face going back out to the garage tonight!
Grinding on again
Hugh
Edited by hughJ, 19 April 2011 - 05:55 PM.
#148
Posted 19 April 2011 - 06:17 PM
Seeing what someone else new to welding does and how they are improving with practice is a giving me the belief that I can do it to ( Not meant in an insincere or condescending manor )
Keep at it and you will get there!
Edited by tino, 19 April 2011 - 06:18 PM.
#149
Posted 19 April 2011 - 07:05 PM
Tack it all round not too close but enough to support it fully. Those flutes not lining up is best to attack it this way. Tack at the top of the U shape and the bottom of the U shape on one side only, then a tack in the middle. Once that's done then attack the other side of the U with a hammer and block to get it to sit right. Do this on all of them.
I would recommend not seam welding as you will blow through as you appear to be butt welding so pulse weld in 1" sections but miss an 1" weld an 1" etc to minimize distortion. It does take a while but worth it. If you are worried about strength then pulse weld on the underside as well.
#150
Posted 19 April 2011 - 07:49 PM
Nice work as usual, the advice on the flutes is good as normal from Neil, glad mine are ok !!! I always use pulse welding as it's all I can do
I agree it does take more time but I'm not in a rush as Matt hasn't started to drive yet !! Also I pulse seam all those sort of panels both sides as they are around the driver, my lad in my case, and want it as strong as possible. This also allows a little grinding down too as weld is on both sides.
Just how I do it, but keep at it.
Graham
