1978 Austin Mini (Cg13 Build)
71 replies to this topic
#46 smudger068
smudger068
  • 344 posts
Posted 24 August 2016 - 09:10 AM
Haha, I didn't realise photobucket had a direct link. Matty is a top guy and is sorting the issue.
Fueling is fine considering its an open throttle body and runs good just need to sort an induction system and filter when money allows as from past experience it isn't really beneficial running an open throttle body.
#47 McMini 22
McMini 22
  • 289 posts
Posted 24 August 2016 - 09:57 AM
Yes. Just click on any photo and it opens up photobucket in a new tab. Hope you don't mind.
Space is tight but I think my air filter should fit.
#48 smudger068
smudger068
  • 344 posts
Posted 24 August 2016 - 11:01 AM
You go for it haha.
That's cool you having an induction come filter kit?
#49 McMini 22
McMini 22
  • 289 posts
Posted 24 August 2016 - 11:57 AM
No just a cone on the end of the throttle body.
Like this -
It's not going to get much cold air up there but I was thinking of running a duct from the grill to up near the filter.  Going to be a suck it and see kind of thing as it might be ok the way it is.
#50 666junky
666junky
  • 1,225 posts
Posted 24 August 2016 - 12:00 PM
Mine is like that and works perfectly :) plenty of flow to the intake but i may still put ducting there in the future just to see what happens. Be careful as ive had overheating issues at 80mph+... no idea why!
#51 l_jonez
l_jonez
  • 1,453 posts
Posted 24 August 2016 - 01:21 PM
Many years ago a guy did a report on engine bay temps ( think it was on minifinity before the crash) in the mini. He went about it properly with temp sensor in Various locations etc and what he found was over 30mph (I think) the air temp was the same as outside which negated the use of cold air intakes.
#52 smudger068
smudger068
  • 344 posts
Posted 24 August 2016 - 01:53 PM
Did you get that filter off eBay? It was what I was looking to do but put it closer to the grill like shinglers build.
Cool!
#53 McMini 22
McMini 22
  • 289 posts
Posted 24 August 2016 - 04:54 PM
Yes its an EBay job.
They had one with a built in ram pipe that I fancied but it was much longer and would foul the triangular strengthener on the inner wing. It might however fit down the front next to the clutch arm with ducting to the TB.
I'm pretty sure your FF inlet manifold offers more room for a filter than my home made job (but it doesn't look as good!).
But if under bonnet temp is not a problem then I wouldn't bother.
#54 smudger068
smudger068
  • 344 posts
Posted 22 October 2016 - 09:54 AM
Hello all.
Small update. Final got a filter system sorted.
Just sorting out rose jointed steering arms to eliminate as much bump steer as I can because it's all over the place.
Had the car weighted and four wheel aligned so feel much safer. Will follow pics of jointed arms soon.
#55 smudger068
smudger068
  • 344 posts
Posted 27 March 2017 - 05:38 PM
Evening all, hope we are well.
Having the mini on the road for a while and I really dislike coilovers, to be honest there simply dangerous on the road and possibly on track if all was to go wrong.
I finally have Hilos and Red Spot Cones.
I have been researching and with my setup and info off minispares I needed to loose some material. So I attacked them with the lathe but I was also keen to keep the locking nut.
Looking to get them installed asap as I have a track day at Snetterton next month.
#56 smudger068
smudger068
  • 344 posts
Posted 26 April 2017 - 07:00 PM
Evening all,
Had a good track session at Snetterton
Alternator didn't hold up all day and had an epic off! Haha. All great fun!!
#57 thelegg
thelegg
  • 608 posts
Posted 27 April 2017 - 07:32 PM
Nice pics :) what happened to your alternator then ?
#58 smudger068
smudger068
  • 344 posts
Posted 28 April 2017 - 11:40 AM
This happened:
I was rather impressed with how it failed. One because the stainless steel bars didn't break at all. Second my welds didn't move (at the bottom.)
The plan is to refresh the metal and have a rubber support under the alternator going onto the subframe. I don't want to bolt it to the subframe for obvious reason but I just need to try and absorb some of the flexing! Without it looking to heavy handed.
#59 McMini 22
McMini 22
  • 289 posts
Posted 28 April 2017 - 02:02 PM
Rather than a rubber off the subframe, would it be possible to attach the back end of the alternator to the block.
Something like this (apologies for the drawing!)
#60 lawrence
lawrence
  • 1,339 posts
Posted 28 April 2017 - 03:01 PM
Or make something similar to my overkill mount!
