1978 Austin Mini (Cg13 Build)
71 replies to this topic
#16 850mini
850mini
  • 43 posts
Posted 26 December 2011 - 06:50 PM
Looks great!
I'm near Colchester, I reckon I'll mine dynod at the same place :)
#17 smudger068
smudger068
  • 344 posts
Posted 26 December 2011 - 08:41 PM
yeh i would i defo recommend without a doubt, east anglian mini centre use him all the time i beleive :D
#18 smudger068
smudger068
  • 344 posts
Posted 19 August 2014 - 07:54 PM
Right I thought I would top up my thread as I haven't replied for a few years.
Well during this time my mini has been through a few track days included Cadwell Park, Brands Hatch and Snetterton,
It was fairly reliable, having a high maintenance girlfriend is the best way to describe it haha.
Anyway, Cadwell Park
396082_10151105003811147_401520861_n1_zp
602532_10151105002791147_1858191121_n1_z
8057_10151105014816147_1386510529_n1_zps
524127_10151105012041147_1446380495_n1_z
Few from Brands Hatch
Then the power and slight overheating issues and a rebuild inevitable at some point I decided on the Micra conversion instead
First made the frame...
Then got a steal on these carbs which are 36mm which seems to be ideal...
Then stripped and put them through the blaster...
All in...
10602798_10152662545119511_2131375648_n1
I was actually trying to fit the moustache at this point still not convinced on the idea of these though
10602717_10152662543804511_2111552349_n1
Then I purchased these one for looks and two to hopefully stop the tyre flexing over so much...
20140816_201317_zpspe3d1gov1_zps2ffd6e48
20140816_201345_zps9pr23rms1_zps2b4b8d09
Still so much to do I will be updating as I go along...
#19 smudger068
smudger068
  • 344 posts
Posted 22 December 2014 - 10:28 AM
Small update with a few pictures:
I am not convinced by this whole home made frame as well as losing my house, workshop and the distribution of all my tools.
So I have more or less been left with the basics so therefore after Christmas I will be purchasing an Allspeed Frame to just get it done.
In the mean time I could sort issues such as mounting the Chrome mirrors, fitting the fuel pump and other small stuff:
Few Pic before it gets torn down again.
Enjoy!
#20 l_jonez
l_jonez
  • 1,453 posts
Posted 22 December 2014 - 10:57 AM
Nice to see another Micra build, I used the same carbs and they worked fine. Good luck with the rest of the build!
#21 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 22 December 2014 - 11:30 AM
Very nice, sorry to hear about house/workshop etc!
#22 smudger068
smudger068
  • 344 posts
Posted 22 December 2014 - 03:20 PM
Jones
I am looking to do the manifold the same as you, do you know what grade aluminium rod was used by you and the engineering company.
Also what modifications did you do as in jets etc to begin?
Edited by smudger068, 22 December 2014 - 03:22 PM.
#23 l_jonez
l_jonez
  • 1,453 posts
Posted 22 December 2014 - 05:09 PM
Rod grade I'm not sure the first one I did was brazed together which worked but was a pain in the rear.
The standard jets should be 135 which should be a good starting point I went up to a 155 but I have some extra cc's
#24 smudger068
smudger068
  • 344 posts
Posted 22 December 2014 - 06:23 PM
Excellent Thank you
Did you buy separate jets or just drill them out?
Does 135 mean 1.35mm and 155 mean 1.55 mm
#25 l_jonez
l_jonez
  • 1,453 posts
Posted 23 December 2014 - 12:30 AM
I just drilled them out but I did buy a second set of jets but I can't remember what size they where ( possibly 145)
Yep 135 = 1.35 etc
#26 smudger068
smudger068
  • 344 posts
Posted 21 February 2015 - 03:54 PM
I finally have my touch of Allspeed  :D
I also have Minispares rose jointed lower arms so need to see how that is going to turn out. I am also going to be modifying the original adjustable castor arms
So next week end we should be off !!
#27 666junky
666junky
  • 1,225 posts
Posted 21 February 2015 - 06:20 PM
Can you document how you are using the bike carbs at all? (Ive also got the same setup but not installed yet as im a bit clueless) - What parts of the loom will you need to run it just on carbs and dizzy?
Also the alternator - im still finding it difficult to see where its going to fit / how to use the mounting kit supplied by allspeed >_<
Should be done around the same time as im at the same stage as you :) - Will have to compare cars as im only a few miles away near southend :)
Make sure you keep the frame at room temp when painting, mine has some real crazy paving effect due to the shed being cold when i painted it.. also degrease it extremely well!! got some paint peel in places where the primer cant stick that well.
#28 smudger068
smudger068
  • 344 posts
Posted 21 February 2015 - 07:06 PM
Hello Chap.
I am planning on using a dizzy in the same way as the mini does in this case a micra K10 dizzy. Then using the drive gear from the k11 to build a hybrid as such. This will allow me to keep the loom I have going to the original coil. i am then going to use original oil and water gauges (smiths) by making them fit to the micras original unions.
I have a four core rad aswell and looking to use it in the original place by adding metal to the original frame to mount it.
As for the alternator I am having to get back to you. Aswell as the manifold for the carbs im unsure of to.
I am by no means suggesting that the ways I am thinking of doing things is the best but its what I can afford and potentially do with what I have and without cutting the shell.
Excellent chap thank you. We certainly will have to. I was going to build it all up then get it powder coated.
Hope this helps
Lee
Edited by smudger068, 21 February 2015 - 07:33 PM.
#29 666junky
666junky
  • 1,225 posts
Posted 21 February 2015 - 08:15 PM
Hello Chap.
Hope this helps
Lee
You'll have a fright when you meet me, im a lady :P
Good idea with the powdercoating, i would have sent mine off for coating but time is a strict restraint for me >_<
I'm really trying not to cut the shell too - the bulkhead must stay the same and im trying to keep as much of the inner wings as possible.
Using the original rad seems to be the way forward as ive heard the piping just falls into place. In terms of temp sensor ive got a very early thermostat housing that i can fit a mini sensor into and utilise the original mini loom for this part - maybe something to think about?  Will be interesting to see how eachothers projects move on etc :)
#30 smudger068
smudger068
  • 344 posts
Posted 21 February 2015 - 08:44 PM
O shes a lady haha.
Yes I have seen them I must admit I forgot I saw that. I think I may order myself one.
