Pete and Ade's Z-cars
Ade
, Dec 11 2005 04:55 PM
86 replies to this topic
#76
Posted 17 December 2005 - 08:28 PM
Watch it with the clutch, if you press it too far it will destroy everything as I found out. I can tell you a good mod if you are interested.
#77
Posted 17 December 2005 - 08:33 PM
Go on then, tell me. This is the second time it's happened so I need some type of cure.
#78
Posted 17 December 2005 - 08:42 PM
You need to change to the old type of slave cylinder that has the circlip in the end. Then get some 22mm thick walled tubing (i can send you a piece that is the perfect size if you cant find any). Cut a piece about 1 inch long, slip it inside the slave cylinder and refit the circlip. This will limit the travel and stop you destroying your clutch housing etc. You will need to keep taking it out and cutting a bit off to get it absolutely correct, better to start with it too long and keep trying the pedal. Mine was about 20mm if i remember correctly, yours could be different on the injected engine.
What type of spring are you using and how have you fitted it? any pics?
You can see pics of mine somewhere on my thread i think.
Chris puts a pedal stop on the hyabusa, but this doesn't stop you destroying the clutch if you press it quickly more than once. With the slave mod it is impossible for it to move too far. Mine has been perfect ever since.
#79
Posted 17 December 2005 - 08:49 PM
Track time was like this! Not ideal for fast laps! :nugget: :grin:
Posted 17 December 2005 - 08:57 PM
Dale
I've tried various different springs ranging from a mini throttle return spring to a deck chair spring. Ade's work fine but I just can't seem to set mine up. Will hav eto try your mod and see if that helps.
couple more pics so you can see how ugly we are :fear:
#81
Posted 17 December 2005 - 08:59 PM
And me at the tollgate. (my misses made me put this one on here)
Does my bum look big in this
#82
Posted 17 December 2005 - 09:00 PM
Have you tried a normal mini clutch spring? Thats perfect on mine.
#83
Posted 17 December 2005 - 09:07 PM
I am so jealous of you're bike engined minis, just can't wait to begin mine!
#84
Posted 17 December 2005 - 09:29 PM
Guys, you sooooo should of said it was at Brands, would of loved to come and watched!
#85
Posted 17 December 2005 - 10:09 PM
Great cars guys, congratz!
Get some vidz of the action...com'on! heh heh heh
#86
Posted 17 December 2005 - 10:40 PM
cars are lookin awesome, look forward to seein them in the mag,
#87
Posted 18 December 2005 - 10:53 AM
Will definately be buying a copy of that magazine!
Bike engined minis are the best!
