Crank Balancing
#61
Posted 08 November 2010 - 08:04 PM
It says can be used with an uprated orange one but preferabely a grey type. As i may have the grey type with the flywheel etc then would it make sense to use it or would i definately be better off using an orange diaphragm as i haven't had any experience with either clutch diaphragms.
#62
Posted 08 November 2010 - 08:06 PM
#63
Posted 08 November 2010 - 08:11 PM
Does it mean you can't slip the clutch then?
#64
Posted 08 November 2010 - 08:13 PM
you may get similar results with a very heavy (grey) spring and a standard plate as you would with a lower duty spring (orange) and a ceramic plate..... that is to say once it is all engaged and moving, the overall characteristics will be very different.
#65
Posted 08 November 2010 - 08:15 PM
on the other hand a ceramic clutch will NEVER suffer with a primary or rear crank seal failure... as they are impervious to oil
#66
Posted 08 November 2010 - 08:17 PM
it will slip just not that easy to slip, more inclined to grip.... can also be seriously damaging for gearboxes and other drivetrain items.....
do you mean all paddle clutches?
because mines deffinatly slipping and iv got a 190mm finger paddle clutch due to an oil seal issue
#67
Posted 08 November 2010 - 08:18 PM
Yeah i've heard that and it has been getting me a bit worried, i'm guessing it's because of less clutch travel as some paddle type clutches can be 2mm or something thicker than the other standard type clutch. I would however be inclined to give it a go as i did get the assembly for a fair bit under the price of that clutch and then if needs be i could possibly change the clutch for a more suitable one at a later date if i don't get on well.
ive driven an mg midget with a clutch like that, it is either on or off, you cant slip it, youll just cook it up. that was a full out race car, i wouldnt like to run one of those clutchs on the road, wont last long and would be horrible.
Edited by samsfern, 08 November 2010 - 08:19 PM.
#68
Posted 08 November 2010 - 08:20 PM
Evan.
Edited by 1977 Loud_Mini, 08 November 2010 - 08:23 PM.
#69
Posted 08 November 2010 - 08:22 PM
That doesn't sound good then, why won't it last long if you can't really slip it?
#70
Posted 08 November 2010 - 08:27 PM
we have to change the one in the midget every season, and it only does about 10 races.
#71
Posted 08 November 2010 - 08:28 PM
I did answer your PM, I will PM you.
#72
Posted 08 November 2010 - 08:31 PM
They don't tend to wear out that quick, the cheaper varieties can break up, or at least they used to but still worked ok, I have had several on the road with orange and grey diaphragms, can be a handful in the wet as the wheels tend to wheel spin more and with a race cam you either bog down or wheel spin for ages........ unless you have a really low ratio diff.
Ah right well i guess the combination of this clutch and a 296SP cam doesn't seem like a logical option then, if i don't ask for others opinions then i'll never know what they're like unless i give it a go so thanks for all the help everyone. Regarding the PM, it never came through so thanks for answering again.
#73
Posted 08 November 2010 - 08:39 PM
http://www.minisport...o_C-AEG481.html
http://www.minisport...o_C-AHT596.html
#74
Posted 08 November 2010 - 08:44 PM
this is what ive been using in mine, seems fine.
Thanks for the links, will have to look into possibly changing the cutch setup. Does th setup your running feel ok when you engine comes on cam or isn't it fully run in yet?
#75
Posted 08 November 2010 - 08:48 PM
i can still slip my clutch, i can drive in traffic but to to my mechanicle linkage changing the pivot point its a very heavy clutch and when i did london to brighton my knee swelled up.
saying that i can drive for normal about 1/2 hour or so without any problems in traffic
