Crank Balancing
#16
Posted 02 November 2010 - 08:59 PM
#17
Posted 02 November 2010 - 09:04 PM
#18
Posted 02 November 2010 - 09:14 PM
There's a big differnce between a central oil pick up pipe and a dry sump, I wouldn't want someone who can mix the two up working on my engine!
who mentioned central pick up pipe?
#19
I would recommened getting the balencing done, i wasn't sure about getting mine done when i built my engine but i built my engine with the idea that i would gradually increase performance as and when, so i done it right first time and built it up with parts that i didnt really need for my spec but knew i would need if i ever upgraded... which i am now
my engine builder found my crank to be out of balance by 17 grams, doesn't sound alot but when things are spinning at 6000rpm+...
and also try shopping around and find someone who actually know alot about minis, to balance my crank and flywheel assembly was £60 and rods and pistons were £45
#20
Posted 02 November 2010 - 09:22 PM
you can dry sump a mini engine.
how do you manage that? my windage tray has been modified in both plains to find clearance for gears and also crank
#21
Posted 02 November 2010 - 09:55 PM
will see if it's handy and get couple of pics but he's got a living room full of bits and i do mean stacked about 6' high!!
don't know how the box was done as he aint got that with it. has got a pump bolted on where the fuel pump would go.
don't know if it was done by turner tuning as it came with two turner twin cam engines he bought but think they only did rear wheel drive stuff??
this is deff. transverse engine though.
have a look on google, can't remember what it was on but read a couple of bits about semi/dry sumped transverse a series somewhere.
Edited by ANON, 02 November 2010 - 09:56 PM.
#22
Posted 02 November 2010 - 10:06 PM
it's simlar to that one. the tank that came with it was pretty big, looks like it would hold a good 3 gallons.
#23
Posted 02 November 2010 - 10:22 PM
Looks more like a minor/spridget lump to me as its rear wheel drive and will have the gearbox behind the engine not underneath.
#24
Posted 02 November 2010 - 10:54 PM
Thats not a mini engine??
i know, it's just similar set up to the one my mate has got. his is deff transverse engine. as said don't know if it's poss something turner tuning did?
#25
Posted 03 November 2010 - 06:20 AM
But in this case, there is no point.
#26
Posted 03 November 2010 - 06:28 AM
#27
Posted 03 November 2010 - 08:56 AM
#28
Posted 03 November 2010 - 10:24 AM
Evan.
#29
Posted 03 November 2010 - 11:25 AM
i'm not getting why a 1380 won't rev almost as well as a smaller engine built on the same bottom end. The breathing characteristics will change, lowering where it produces the best torque and power but you may well want to run it at higher revs.
#30
Posted 03 November 2010 - 12:49 PM
