Spraying In Garage
Posted 27 October 2010 - 08:58 AM
cheers
jake
Posted 27 October 2010 - 09:57 AM
hi wondering if anyone knew the best way to spray the front of my car, but only in my garage so don't have an extractor or anything, without it being a poor job looked at compressors but in other topic's people say they need to be 5hp and they cost a fortune, wondered what people thought of hvlp turbine sprayers or if anyone knew of any others way to spray.
cheers
jake
I use a 2hp with 150 litre tank and get very good results using cellulose - even a small compressor should be able to cope with spraying a smallish area - say two wings and boot. I don't have an extractor fan but use plastic decorator sheets to line the garage (especially the floor to stop dust blowing up ) and leave the garage door up and choose a warm sunny day when its not windy ! tricky !.
I get a good finish by cutting back the new paint using cutting paste, t cut etc so put plenty of coats on, but have never sprayed metallic finish or two pack paint which needs air breathing masks etc.
remove as much trim as you can and mask off everything else - its the prep that gets good results use panel wipe to de-grease first- the actual spraying is only a small part of the process and a smallish compressor should be able to get good results. havn't used a hvlp but again, if your not doing a complete respray it should be up to the job
a small compressors very handy to have and your unlikley to get much change from £300 to pay a paint shop to do it for you, so give it a go !
Posted 27 October 2010 - 10:30 AM
good lick
Posted 27 October 2010 - 03:56 PM
Posted 27 October 2010 - 06:01 PM
Posted 27 October 2010 - 07:40 PM
http://cgi.ebay.co.u...=item563fb155d5
thanks again
jake
Posted 27 October 2010 - 07:47 PM
oh and i used a powercraft compressor from aldi! lol
Edited by olds_kool_lews, 27 October 2010 - 07:49 PM.
Posted 27 October 2010 - 08:03 PM
Just painted my car in the garage with a 1.5hp 25litre compresser and it coped fine. I used 2k paint which comes with a harder so doesnt matter about it been cold and if you get dust in or runs you just flat it off then compound it to a nice shiny finish.
It does matter if it is cold. should not paint 2k below around 14 deegrees it will not dry properly
Posted 28 October 2010 - 04:23 PM
With a bit of practise you will find easy enough to spray the front of your car.
As others have already said you can really only spray cellulose safely with this compressor. Although you can get metallic colours mixed in cellulose it would be hard to get a good match with existing paint (unless you were respraying the whole car).
Posted 29 October 2010 - 04:47 PM
My mistake didn't literally mean freezing cold just meant it didn't need to be baked on
Posted 05 November 2010 - 12:51 PM
You definitely need a moisture trap on the airline. With celly, I found the best way to flat it afterwards is to use Maguires 1500 grit finishing paper, as it doesnt disintegrate when wet, like ordinary wet-or-dry does.
Then I used Furecla G3 cutting compund, then resin polish and hey-presto!
This is my restoration below, all done in my garage using celly.
I just used a 3HP compressor with a 50L tank, and it was fine. You may find that using a HVLP (High Volume low pressure) gun will serve you better with a smaller compressor like mine, as more paint goes on the car with less expelled into the air. I have a devilbiss one, expensive but brilliant. But I think you can buy other ones cheaper and it all depends on your budget and hom much flatting of the paint you are prepared to do afterwards.
But your prep doesn't just mean what you do with the car. Ensure your garage is clean and dust free, blow dust away from the ceiling and walls using your compressor, or brush etc, wet the floor etc. Also, you need good lighting.
With lighting, do not use incandescent bulbs, as this could ignite the vapour. Floresecent strips will do the job instead.
Also, do not have your compressor in the garage while spraying, as the motor gives off sparks as it oprerates which again, could ignite the vapour with a loud bang!!!! Perhaps no one will notice if you did it tonight as its fireworks?!!
Edited by mk=john, 05 November 2010 - 12:56 PM.
