My Mini 3 Rally Car Project
152 replies to this topic
#106 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 25 January 2013 - 04:49 PM
I'm not sure, may be able to find some decent scales and weigh it, 2 people can lift it though as it is, pretty heavy but I'm only 68kg so not He-Man!!!
I'm fabricating the rear beam and tubular radius arms next so I can put it on its own wheels, will be easier to paint the roof then!
#107 matthew25
matthew25
  • 57 posts
Posted 29 January 2013 - 10:22 AM
morning pal shell looks great what colour white is that?
matt
#108 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 29 January 2013 - 04:01 PM
It is pure white- I went to a paint supplier and was going to get Ford Frozen white mixed up, but they said it would be a little cheaper to go with pure un-mixed white, as they receive it in bulk before they tint it, so I did, in theory you can't get whiter!
#109 kcchan
kcchan
  • 874 posts
Posted 29 January 2013 - 07:50 PM
Looking sweeter now it's in paint
#110 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 30 January 2013 - 12:00 PM
Painted the roof earlier, even happier now! (I can't get photobucket to work half the time on either of my 2 internet browsers, so using flickr as well- getting confusing...)
And both parts of the roof scoop:
Edited by C4NN0N, 30 January 2013 - 12:01 PM.
#111 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 30 January 2013 - 12:01 PM
Very nice
#112 matthew25
matthew25
  • 57 posts
Posted 30 January 2013 - 01:45 PM
cheers for that cannon shell looks amazing with the white and black can't wait to see some shiny bits on.
#113 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 30 January 2013 - 02:43 PM
I believe you are catching me up! looks fantastic!!
#114 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 06 February 2013 - 04:27 PM
I've been doing a bit on my own rear beam set up, have made the beam (4mm steel- a bit overkill but I wanted it strong and rigid, would use 3mm next time though), aligned the holes and drilled for 1/2" UNF male rod ends.
Here is what I'm doing, just a mock up on AutoCAD so I can pull off the dims, didn't see the point in doing a Solidworks model as I'm quicker on AutoCAD at the mo!
The main tubes, with bosses turned to fit to take bolts/studs to fit to the beam. I'm going to bend the next tubes tonight with any luck, then I'm going to build a jig so I can get 0.5° Camber built into the arms accurately.
And finally the bosses I turned to take standard stub axles, laser cut backplates should be with me soon so I can weld them all together!
#115 minisi35
minisi35
  • 723 posts
Posted 06 February 2013 - 05:00 PM
very impressive :highfive:
#116 hoody99
hoody99
  • 699 posts
Posted 07 February 2013 - 12:27 AM
Loving this thread mate keep it coming
Also I like how you moved the rear harness mounts back can you make these to order ?
#117 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 07 February 2013 - 08:24 AM
Thanks, do you mean the lap belt fixings, on the floor? The rear (shoulder) straps are being wrapped round the horizontal bars in the cage cross.
#118 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 07 February 2013 - 12:28 PM
the roof scoop looks mint!
hope the radious arms come out well
#119 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 07 February 2013 - 06:35 PM
Bit of progress today- made a very substantial jig for my radius arms, I have built 0.5° camber in so it ended up taking a while and had to be handed for each side too, it's square within approx 0.25mm, level to 0.1°, and will make it easier if I make any more in the future!
Here's a couple of pics, going to be 100% TIG welded too, figured it would be neater, a better quality weld and a bit lighter too!
TC
#120 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 07 February 2013 - 07:45 PM
Update- just finished welding up one of the arms, pretty happy with it too- will have to see how it holds up! Just waiting on laser cut backplate brackets but they are straightforward to weld on as they fit over a shoulder I machined into the hubs.
Not got any scales here to weight them with- but feel a LOT lighter than standard!
