My Mini 3 Rally Car Project
#46
Posted 27 July 2011 - 09:51 PM
#47
Posted 27 July 2011 - 10:14 PM
where'd you get it? can you send me a link?
and keep up the good work!
#48
Posted 28 July 2011 - 09:32 AM
Just google Snap On and get hold of your local dealer, its a franchise and you will have a local man.
Edited by C4NN0N, 28 July 2011 - 09:33 AM.
#49
Posted 23 August 2011 - 04:18 PM
#50
Posted 24 August 2011 - 07:38 PM
Thanks C4NN0N, is there any advantage using tubes rather than square section?
I think it is to prevent tension building up in the corners of the square tubing. If the tubing is round then the tension is spread over the entire surface. That's why commercial aircraft have round windows, to prevent tension building up in the corners because this can result in cracks.
#51
Posted 13 November 2011 - 08:23 PM
#52
Posted 14 November 2011 - 03:44 AM
#53
Posted 14 November 2011 - 09:47 AM
#54
Posted 26 March 2012 - 08:27 AM
Well it's been a while since I updated this- and the car doesn't really look much different!
Edited by TopCatCustom, 22 February 2023 - 09:41 AM.
#55
Posted 27 March 2012 - 08:09 PM
keep going mate watching this one :)
#56
Posted 12 April 2012 - 02:34 PM
A little progress, have been working on brackets etc, and fabricating new steering column brackets (and column) which is tilted, however I'm not sure I will bother to use them as it's a lot simpler and more reliable having a straight shaft with no joints etc in.
Edited by TopCatCustom, 22 February 2023 - 09:44 AM.
#57
Posted 13 April 2012 - 02:53 AM
#58
Posted 13 April 2012 - 09:03 AM
#59
Posted 13 April 2012 - 11:41 AM
was hoping youd be able to take a pic from underneathe so we can see how youve achived it
thanks
Danny
#60
Posted 13 April 2012 - 01:17 PM
I'll get a pic at some point, can also supply any of these parts if you require as it's what I do!
