Where did you get yours from?Yes the ITG ones are about 80. My one was 98 and IMHO well worth the extra
Liirge, hows your engine coming along?
Posted 05 November 2010 - 02:27 PM
Posted 06 November 2010 - 02:22 PM
Posted 06 November 2010 - 03:23 PM
I think hot 998s a more satisfying than dropping a big bore inA hot 998 may be a plan
Posted 07 November 2010 - 12:47 PM
well not that well if im honest! seems to have stalled again, the engine is in 3 or 4 main bits, needed to be bolted together! but i wont do that till I've got the car all prepd and ready! and im not at home at the moment, and its cold outside (as you can tell its just excuses!!)Where did you get yours from?Yes the ITG ones are about 80. My one was 98 and IMHO well worth the extra
Edited by liirge, 07 November 2010 - 12:48 PM.
Posted 07 November 2010 - 04:31 PM
DONT DO IT MATE!!I might sell the lot if im honest!
Posted 17 November 2010 - 10:46 AM
Posted 18 November 2010 - 12:22 PM
well, if ya dont want to go to the bother of swapping engines but want a bit more poke, I would say put a stage 1 kit on with an ultralight flywheel and backplate. These parts can be installed without taking the engine out/rebuilding it.what would you recommend to me
Posted 03 December 2010 - 12:47 AM
Posted 03 December 2010 - 01:11 AM
Posted 03 December 2010 - 01:16 AM
What's the valve size that head?
looks MG style to me!
Edited by PhilipGCaldwell, 03 December 2010 - 01:19 AM.
Posted 03 December 2010 - 01:27 AM
Posted 03 December 2010 - 01:38 AM
with the cam Im putting in (kent 276) I should have at least 50 thou clearance at full lift, measured each pocket with vervier calipers so it accurateThose pockets look pretty shallow, mine are much deeper. Unless its just camera trickery
Posted 03 December 2010 - 12:02 PM
Posted 03 December 2010 - 03:19 PM
Posted 03 December 2010 - 04:56 PM
used a die grinder to pocket itWhat did you use to do the pockets?
Correct again, measured them before and your right. Plenty of flow with tose size valves and the porting ive doneThe inlets on the MG head are 35.7 and exhaust is 29.5
