1275 Eating 998
486 replies to this topic
#466 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 19 November 2012 - 02:41 PM
Why fit a different camshaft to it if you're scared to utilize it?
Let it rev!
I agree to some extent, it would be nice though to have something where the power is a little lower down the rev range so I dont have to make it scream everywhere!
If the engine has to come out for any reason I will change to a 266 or something similar
also future modifications will be to change exhaust as the one fitted isnt suited to a 998, its a 3 inch fletcher, when I bought it at the time I had no idea on engines or whatnot so just thought bigger was better, need a smaller unit
#467 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 19 November 2012 - 07:03 PM
have you got any onboard footage?
thinking of building a similar spec engine, would be great to see what it goes like :P
#468 jaydee
jaydee
  • 8,565 posts
Posted 19 November 2012 - 08:00 PM
The beauty of the 998 is that at 4.5k rpm goes bang to 7k rpm..one of the reason why i ditched the 276 because i was revving it all the time up to 7000/7200, engine wont have lasted long.
#469 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 20 November 2012 - 02:10 PM
This is my printout, as you can see the torque has pretty much peaked, at around 190lb/ft, the hp figure is nearly a perfect straight line that shows no indication of slowing down, so looks like it will peak somewhere in the 50's
This is Paul's printout, the torque peaking at 239 lb/ft, but notice that the hp figure has pretty much peaked by 5000rpm
#470 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 20 November 2012 - 02:24 PM
190lb/ft!?? That cant be right! Thats diesel/turbo territory!
Even the A-series turbo only managed (albeit limited) 85lb/ft!
#471 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 20 November 2012 - 02:43 PM
god knows, thats just what the graph says, does sound wrong
#472 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 20 November 2012 - 02:50 PM
maybe it reads 18.7 and 23.9 lb/ft, I think the decimal point might be obscured by the line on the graph? My old 998 only only managed 38lb/ft toque so 187 rather too much of an increase!!! Maybe its how Im looking at the graph,hmmm, anyone?
Edited by PhilipGCaldwell, 20 November 2012 - 03:02 PM.
#473 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 20 November 2012 - 08:12 PM
I would have said it was in Nm but that still puts it around 135 lb/ft. I think the RR needs re-calibrating!
#474 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 20 November 2012 - 08:15 PM
Reversal of the HP equation shows it to be about 60lb/ft @ 4000rpm. Which sounds about right!
Equation is:
HP = (Torque x RPM)/5252
Edited by Tommyboy12, 20 November 2012 - 08:16 PM.
#475 tb205gti
tb205gti
  • 186 posts
Posted 21 November 2012 - 10:08 AM
That printout is not right. :/ Only 5 points measured and torque that is WAY off..
#476 OfMini&Men
OfMini&Men
  • 284 posts
Posted 18 December 2012 - 02:43 PM
Good little engine you've built, good to see small bore's being used instead of rusting away.
I'm currently finishing off my mini sticking a stage 1 998 in then finish building a 1060 off set twin cam super charged engine once I've picked the head and charger up should be a mean little bit of kit.
#477 Sam Walters
Sam Walters
  • 2,765 posts
Posted 19 December 2012 - 11:53 PM
5000rpm = 45hp
4000rpm = 32hp
3000rpm = 20hp
hp*5253/rpm=torque
20*5253/3000= 35
32*5253/4000= 45
45*5253/5000= 47
#478 steven
steven
  • 1,195 posts
Posted 20 December 2012 - 07:37 PM
just read the whole thing lovely engine !
#479 Cooperman
  • 23,325 posts
Posted 02 February 2015 - 11:39 PM
For a 998 with a 276 to work you simply have to rev it to around 6400 rpm. Peak power will be at about 6200 rpm.
It does sound as though you have 'over-cammed' it with the 276, but you clearly realise this.
A 266 will peak at about 5800 rpm in a 998 which is fine so long as you do the RR run to 6000 rpm.
Maybe you could consider the old BMC AEG510 Cooper 'S' cam which is very nice in a 998 and the one I built with a 510, plus a lot of other work gave 66 bhp at 6000 rpm.
The 998 does like to be revved, so don't be afraid to do so.
#480 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 03 February 2015 - 12:11 AM
Holy thread revival batman!
