1275 Eating 998
#406
Posted 25 February 2012 - 01:54 PM
the air fuel ratio is all over the show, desprrately needs a custom needle
all in all, quite pleased
#407
Posted 25 February 2012 - 03:27 PM
#408
Posted 25 February 2012 - 03:33 PM
#409
Posted 25 February 2012 - 06:08 PM
#410
Posted 26 February 2012 - 04:37 AM
I'd hope near the 60 mark once its all tip top and can rev it to near 6k, the air/fuel ratio was waaaay way out on the gauge, running around 22/1, too lean
That is really, really lean, should run a lot better with the timing and fuelling sorted.
#411
Posted 26 February 2012 - 11:23 AM
#412
Posted 26 February 2012 - 11:34 AM
#413
Posted 26 February 2012 - 08:23 PM
Running lean will definately eat your spark plugs.
Anyway,
WinSU is a very good program for figuring out needles. At 10 quid it's cheap. I got it because I'm putting 2 HS4s on a 1.3 Marina engine in my Frogeye.
Enough babbling. I ran these specs through WinSU:
998 std bore
single HIIF44
mesh filter on rampipe
minispares manifold
12G940 head ported
Kent 276 cam
1.3 rockers
LCB medium bore
mapped distributorless ign.
They may be wrong, but that's what I remember now without searching the last 15 pages.
I don't remember what needle you have, but WinSU comes up with best; BBZ, next up; AKN.
BBB, BBZ and AKN look spot on each other up through transition to midrange, BBB runs very slightly richer all through midrange then becomes too lean towards high end. BBZ goes a bit richer towards top end and AKN too rich towards top end.
The program also claims 60.7 HP flywheel and 47 HP at wheels.
#414
Posted 26 February 2012 - 09:06 PM
I've been following this thread for a while and I've been inspired. It's really great to see what can be done with the small bore, on a budget too.
Anyway,
998 std bore
single HIIF44
minispares manifold
12G940 head ported
Kent 276 cam
1.3 rockers
LCB medium bore
Thats good info buddy, thank you, looks like I will try the BBB needle first off see how she does, she really needs a RR desperately
#415
Posted 27 February 2012 - 12:34 PM
if its a HIF44 that you are using then i would start with a BBB needle, that should richen it up enough to finish runnning the engine in, running it too weak could cause piston damage.
+1
No good to run in an engine that is tool lean.
When you say lean, what was the AFR ?
#416
Posted 27 February 2012 - 03:22 PM
#417
Posted 27 February 2012 - 05:21 PM
#418
Posted 27 February 2012 - 08:30 PM
#419
Posted 27 February 2012 - 08:53 PM
I'd be happy with that!
#420
Posted 27 February 2012 - 09:07 PM
arent standard 998's 38bhp standard?.......i didn't realise that a stage 1 kit would provide another 12 bhp, most companies claim an average increase of 20% which would equal about 45 bhp.60bhp isn't bad from a 998 to be perfectly fair. most stage one 998s sit around 50bhp, stage one 1275's sit around 65bhp.
Edited by oltonlad, 27 February 2012 - 09:12 PM.
