1275 Eating 998
#286
Posted 08 December 2011 - 08:52 PM
#287
Posted 09 December 2011 - 07:11 PM
Also fiddled with the timing aswell, I have it set at 8 degree BTDC at 1000 rpm (was running at 12 before)
I didnt grind out the water pump pulley yet so its still noisy!I ran the engine for about 20 mins and the noise was getting quieter and quieter so I may just leave it and let itslef bed in until its silent
gave it a good rev up and the throttle response is much better, no hesitation or flat spots/bogging
Next to do now is adjust my neg camber then I can give it a tinkle up the road
Again, I've been forced back inside the house because its started lashing down with hailstones!
Edited by PhilipGCaldwell, 09 December 2011 - 07:12 PM.
#288
Posted 10 December 2011 - 06:20 PM
got idle mixture sorted spot on 2.5% CO and had a fiddle with timing again its about 6* BTDC now and seems to run luverlee!
Another small gripe, either my thermostat is ferkin buggered or I have an airlock in my cooling system as after I'd run it up and down the road a few times it started heating up and when stopped there was some steam and gurgling from the rad cap, I'm sure its an airlock, will run it with the heater open and rad cap off to get any air out and see what it does from there
tommorow, take some neg camer off so it doesnt rub on full lock/cut arches, also ant to re-do the tappets again, I did them all to 12 thou but guna do them to 15/16 thou now (kent cams figures)
when this is done, shes getting a proper drive up the road
#289
Posted 10 December 2011 - 06:24 PM
#290
Posted 10 December 2011 - 06:49 PM
#291
Posted 11 December 2011 - 10:54 AM
#292
Posted 12 December 2011 - 12:01 AM
also, ran the engine with the rad cap off and heater open and got all the air out the system, not heating up anymore
gave it a good spin up the road and its a bit bloomin loud!!! I cannot believe the noise from it for a 998cc engine, my neighboughs hate me, you can see them looking out their windows at me
it runs well enough but will benefit from a RR session, its just a bit sluggish under 2000 revs but this could be attributed to the 276 cam, once over 1500/2000 revs its very nippy and very loud, induction roar is fabulous!
very happy with the weekends work
EDIT: just another small thing, it has sprung a leak from the timing cover oil seal, but its not too bad
Edited by PhilipGCaldwell, 12 December 2011 - 12:02 AM.
#293
Posted 12 December 2011 - 12:04 AM
Could you get a video up sometime from inside the car when driving
#294
Posted 12 December 2011 - 02:00 AM
Ask nicely for a RR session for christmas
Jesus
#295
Posted 12 December 2011 - 09:52 AM
Sounds good!
Could you get a video up sometime from inside the car when driving?
Yeah, will have a go tonight or failing that, at the weekend when its light again, full throttle sounds amazing, such throaty aggressive purr!
Sounds good mate!
Jesus
Will have to see what Santa says
Also want to get it RR when the megajolt is all set up, will get a mate to fit it but hes a busy lad himself at the moment putting a vauxhall engine in a clubby estate
EDIT:Also not re-done the tappets to 15/16 thou, it went dark, it will possibly run better when set to the Kent cam clearances ie; not be as sluggish below 1500/2000 revs
Edited by PhilipGCaldwell, 12 December 2011 - 09:56 AM.
#296
Posted 12 December 2011 - 10:11 AM
#297
Posted 12 December 2011 - 12:13 PM
#298
Posted 12 December 2011 - 12:16 PM
What is the total build budget to date?
I try not to think about it
reckon about £8-900
#299
Posted 13 December 2011 - 02:46 AM
It might make it a little less lumpy but i wouldnt hold your breath
Jesus
Edited by twrminisport, 13 December 2011 - 02:47 AM.
#300
Posted 13 December 2011 - 09:54 AM
