I am about to get my Mini back from the lad who has been doing welding and body filling and I need to get it painted.
It been in and out of his workshop and all of the bare metal areas and some of the filled areas are obviously rusting up again!!!
I intent to rub down all of the rusted areas and let the filler that he has applied thoroughly dry out before doing any spraying so Ill have to clear out my garage!!
The inside has had some repairs and was rusted in areas as well as a new A Panel, patch repairs to the Sills and small areas of bodywork.
I want to ensure that none of these areas rust up again and having read around it would seem that POR 15 is thoroughly recommended on this and many other web sites. Iv'e just been onto the Frost Web Site and a guide on the site suggests prepping with Marine Clean and Metal Ready first (both also by Frost).
My question is should I follow this advice?
I don't have any spray gear but I am more that happy to brush on POR 15 inside and under the arches and under the car but would opt to spray anywhere else, although I just double checked on the Frost Web Site and found this:
"APPLICATIONS
AUTOMOTIVE: suspension - chassis - doors - trunk areas - engine & fuel tanks - rusty frames - floor pans - corroded battery tray"
So this would suggest not to use POR 15 for body panels, if so what should I use instead to ensure a rust proof treatment on bare metal.
Any replies would be most welcomed.
Edited by JonnyAlpha, 21 October 2010 - 12:00 PM.
