yeah there are 2 in the pictures above ???
My Mini Resto
#601
Posted 27 January 2014 - 07:14 PM
#602
Posted 02 February 2014 - 09:46 PM
Engine is in today !!!
had a big spend up at minispares on saturday. lots of bits including my lowered height gaz shocks which i love !
also cleaned and painted the engine yesterday, fitted; mg metro cam, new cam followers, duplex timing gear, new clutch, new gaskets.
got the engine together and then in the car however one of the captive nuts decided it was no longer held on and span round, was not happy about this, but i will weld it on so no worries there.
still have lots of things to do before i can think about starting the engine, things left are:
- finish mounting engine
- handbrake cable
- connect pedels to master cylinders
- connect gear linkage
- brake lines
- rebuild callipers
- paint driveshafts+ fit them with new boots etc
- fit wiring harness
- water pump+ rad with hoses etc
- clean up exhaust, paint + mount it properly
- sort out the facet fuel pump, mount it and wire it up
- fit fuel tank+ fuel lines
- rebuild carbs + fit them
- fit; dizzy, starter motor etc
- fire that bad boy up hahah
#603
wait for it, i wasnt aloud to put more pictures up so i will now
#604
Posted 02 February 2014 - 09:51 PM
thats all for now i shall be doing small updates in the week of little things i will be doing in the evenings, but all i need to do it keep chipping away at things each night and before i know it i will be pulling it out of the garage not pushing it.
#605
Posted 06 February 2014 - 10:32 PM
Hello mate, i'm Hugo from Portugal and I've see all of your work, and I LOVE IT.
Congratulations for your work, and i will keep looking for your updates.
THUMBS UP
#606
Posted 07 February 2014 - 06:33 AM
THUMBS UP
Thanks a lot Hugo, glad to hear you like it, and the next update will probably be on Sunday, I have the carbs on, water pump,thermostat etc but haven't got round to updating it yet.
#607
Posted 07 February 2014 - 09:35 AM
- handbrake cable
- brake lines
- rebuild callipers
these wheels really look tha part mate! ",
#608
Posted 07 February 2014 - 11:26 AM
Can you tell us how much money have you spent since the beggining ?
#609
Posted 08 February 2014 - 09:26 AM
#610
Posted 08 February 2014 - 09:27 AM
Around £2,000 maybe more :/
#611
Posted 10 February 2014 - 05:05 PM
been busy:
connected up the gear selector
put on gear selector
mounted faccet fuel pump
cleaned up and painted the alternator
cleaned up the fan blade
painted the water pulley pump
polished up carbs and fitted new gaskets
painted up carb heat shield and fitted it.
fitted oil pressure line
fitted clutch cylinder
fitted brake bias valve and painted it
fitted brake lines to bias valve
put push rods in
cut and zip tied the pipercross filters on
fitted new coil
fitted fan belt
lots of little bits really stuff you don't really notice but takes a lot of time and needs to be done so that bigger better things can then be done
#612
Posted 22 February 2014 - 09:07 PM
will have an update tomorrow night engine is being a pain to say the least, doesnt want to start however a mate is very nicely popping over in the morning to save me from this headache
#613
Posted 25 February 2014 - 09:12 AM
Looking good mate, it's come a long way since I saw it! Did you get it fired up?
#614
Posted 25 February 2014 - 09:03 PM
yeah running now, has a misfire which i need to get trouble shooting i believe it is a fuelling issue though
#615
Posted 26 February 2014 - 12:37 PM
Double HS2 ? Nice, I love these carburettors !
