My Mini Resto
#571
Posted 15 January 2014 - 08:27 PM
The engine will remain like this for around two years with maybe a few extra mods over this time however by the time I am 19 the insurance will be much lower and I would have been busy building a 1340 with a 16v head with hopefully around 120bhp !!!!! Cannot wait
#572
Posted 18 January 2014 - 07:53 PM
been busy today trying to mount my bucket seat. first i fabricated a rear box section for the seat which worked but didnt allow the seat to go far back enough, so i had to modify the subframe from my classic cobereau seats. this works and is now in situ. also i have been busy with inside prep and should have it in primer next saturday. then it is bingley hall !!! can wait.
love the feel of this bucket seat as it gives good driving position and feels nice to sit in an so was worth the £40 i paid. also a nice guy called Malcum came down from scotland today to collect my 998 cooper engine. was a little sad to see it go but it is going to a good home and the money gained from this will help me finish the car. thats it for today more tomorrow
box section which worked but didnt give a far back enough position
thanks
Edited by minimk1, 18 January 2014 - 07:55 PM.
#573
Posted 18 January 2014 - 07:59 PM
also want an internal gear selector now !!
#574
Posted 19 January 2014 - 06:23 PM
inside is sprayed in inca yellow!!!!
few places need a rub down as i have one or two runs but overall i am very happy with it. but i hated doing it as the roll cage especially, made everything alot harder to do.
got two coats of primer down before i did 3 coats of top coat. happy with the finish, might buff up areas which are seen so they are shiny hahah next step ENGINE IN. so work from now on will be things like the brake and fuel lines, master cylinders, pedal box etc. oh and of corse a little bit of 998 tuning.
running it with:
- mg metro cam
- lightened cam followers
- lightened duplex timing chain
- uprated 12a185 head with big valves
- double valve springs
- pressed steel rockers
- twin 1 1/4 carbs & trumpets with socks
- oil cooler
- std ignition
mocked up the carpets to see how much they cover as it is alot i didnt go into too much trouble trying to get a pristine finish as it would be wasting time for something that will sit under a carpet for the rest of its life. also getting the hang of spraying so should do a good job of the outside when the time comes. however for now i just want the engine in and running brakes working etc cant wait to do a "first start up in 3 years video" anyway now for the pictures
Edited by minimk1, 19 January 2014 - 06:24 PM.
#575
Posted 19 January 2014 - 08:14 PM
Looking good as always! :)
#576
Posted 19 January 2014 - 08:42 PM
Thank you
#577
Posted 20 January 2014 - 08:55 PM
brought a 2 ton low entry jack today so tested that out as i will be using it alot, also have been busy painting things that are needed to be on the car before the engine goes in
did paint this but didnt get a pic
also brought some ital mirrors off of ebay
#579
Posted 22 January 2014 - 06:40 PM
Posted 23 January 2014 - 06:46 PM
I will be fitting a duplex timing chain cam followers etc, and new gaskets however that is a simple job which can be done after the engine has been painted. Next step for the engine is a big clean and a bmc green paint
Also got my bingley hall tickets
Cleaned up my pistons
Forgot about the oil :/
Mg metro cam at bottom
Put the old timing chain on and that's how I left it for today
#581
Posted 23 January 2014 - 06:48 PM
Look out for me at Bingley!
#582
Posted 23 January 2014 - 07:05 PM
#583
Posted 23 January 2014 - 08:06 PM
Had the day off today so decided to do some engine work taking flywheel and clutch off and then putting in my mg metro cam timing it with the dot to dot method as this will be fine for my spec
Will you take any photo of the mini fair and are you taking your Mini
#584
Posted 23 January 2014 - 08:30 PM
#585
