My Mini Resto
#376
Posted 08 November 2013 - 04:10 PM
#377
Posted 17 November 2013 - 06:17 PM
small update
brought 3 angle grinder discs for my chop saw and what a machine that thing is cuts my 3mm steel easy and fast and is accurate love it, started cutting out my seat mounts, done some more cleaning of the floor and my dad got a new car, a 1959 mk1 tvr grantura that needs a shed load of work, just cant get over how chuffed i am with that saw!!!!!!
#378
Posted 23 November 2013 - 11:01 PM
update as i have been busy today making my solid seat mounts for the front of the seat to bolt onto these are also extended brackets to allow the seat to go further back i have made mine so that i will weld them onto the crossmember but i could have also done these to bolt in to the standard mounts
also got the new source of heat in the garage sorted it is no longer warming up by moving around now we have and actual wood burner setup !!! makes such a big difference
done this and had a big garage sort out so now its nearly neat and tidy thats the update for now, until tomorrow.............
Edited by minimk1, 23 November 2013 - 11:01 PM.
#379
Posted 23 November 2013 - 11:05 PM
#380
Posted 23 November 2013 - 11:12 PM
#381
Posted 23 November 2013 - 11:36 PM
Nice welding !
Thank you, welding this compared to mini steel is so nice
#382
I love the color of this thing! I hope you kept it.
Yep I'm keeping the colour inca yellow and plan to have a gloss black roof
#383
Posted 23 November 2013 - 11:38 PM
Nice! Inca yellow huh? I have never seen that color before. It's super unique. I bet you'll turn some heads.
#384
Posted 23 November 2013 - 11:42 PM
#385
Posted 23 November 2013 - 11:43 PM
#386
Posted 23 November 2013 - 11:44 PM
Edited by minimk1, 23 November 2013 - 11:46 PM.
#387
Posted 23 November 2013 - 11:58 PM
Nice welding !
I bet
#388
Posted 24 November 2013 - 03:56 PM
update i have welded the seat mounts in, drilled holes in this for the seat subframe, removed the latch off of the subframe and fixed the seat runner catch, also i shortened the front bolt mounts on the seat subby so my seat would sit at the correct angle
welded some new bolts in the runner latch as it had one rivit and half a bolt holding it in before
also strengthened my welding trolly as it was abit wobbly so i added some triangles in
#389
Posted 24 November 2013 - 03:59 PM
also had a sweep up and fixed my earthing clamp
update next weekend >>>>
#390
Posted 24 November 2013 - 07:58 PM
Brill stuff as usual. Where'd your fathers mini go?
