1971 Lotus Inspired Clubman Estate
681 replies to this topic
#121 longtimenomini
longtimenomini
  • 708 posts
Posted 02 February 2018 - 03:51 PM
Updates soon, few more pics to keep you keen
Attached File  E4AE68E3-E20A-45C9-B2C9-3CCCB12191F0.jpeg   95.45K   5 downloadsAttached File  F89AB56A-F502-42AA-A4C1-69ED77044D99.jpeg   28.78K   3 downloadsAttached File  F957E154-D475-45B2-B465-541418CD8196.jpeg   23.03K   1 downloadsAttached File  302761E0-E156-461F-ACAA-50E15C33AC27.jpeg   123.21K   1 downloadsAttached File  2B11AAA8-4DEB-44DD-AD71-21640B5025A0.jpeg   87.62K   0 downloadsAttached File  37E4EF35-2C7F-4B1F-AC3C-C26843E9BA8A.jpeg   87.69K   0 downloadsAttached File  480A59A7-FF06-4051-A56A-A90C16FDFDF6.jpeg   96.71K   0 downloadsAttached File  DB001323-A81E-4ED2-9985-5FF32D44182E.jpeg   94.23K   1 downloadsAttached File  68083031-73E0-493D-AA63-59EE10453F24.jpeg   92.04K   1 downloads
#122 MacGyver
MacGyver
  • 1,027 posts
Posted 02 February 2018 - 04:34 PM
#123 longtimenomini
longtimenomini
  • 708 posts
Posted 02 February 2018 - 05:59 PM
Kept a list of new bits bought so far , not including panels... have taken a few things off (surprise for later)
1275 gt Clocks
Under riders
Rear belts
Trim clips
Door Hinges
Headlamp bowls
Headlamps
All window and door seals
More seat belts
Clips for seals
Arch trim and rubbers
Rear Subframe
Dynamat
Petrol tank and fixings
Rear camber plates
Knuckle joints
Lowered Shock absorbers
Wiper boxes and tube
Rear backplates built
2 x Radius arms recon
Track rod ends
Gaiters for rack
Discs and pads
Suspension poly bushes
Adjustable bottom arms
Ball joints
Bleed nipples
Bumpstops
Bearings rears
KAD Quadrants
2 hbrake cables
Rearcap
Lower pins
Front indicators
Front wheel bearings
Carb rebuild
Full Exhaust system inc manifolds
Air filter
Hose clips
horn
Nuts and bolts
Ht leads
Electric fan
Brake lines
Alloy radiator
Thermostat
Gaskets
Interior lamp
Water pump fitting kit
Heater valve
Water pump
Kevlar Hoses
Washer bottle cap
Radiator sender switch
Rocker cover nuts
Accelerator cable
Washer pipe
Temperature transmitter
Oil filter
Heater control cable
Choke cable
Rocker cover cap
Spark plugs
Fan belt
Washers and t piece
Earth and live cables
Door switch x2
Switch seals x2
Subframe kit
Radiator surround
Wheel centres
Wheels and tyres
Alloy callipers
Super fin drums
Remote Servo
Arches
Interior not even started yet .....
#124 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 03 February 2018 - 07:40 AM
This this just looks stunning, cannot wait to see it down on the floor on some wheels... Top work!
#125 Archived1
Archived1
  • Archived
  • 619 posts
Posted 03 February 2018 - 11:07 AM
That garage/shed is great! Did you build it from scratch or buy it and erect it in place? Could do with something like that in my garden
#126 longtimenomini
longtimenomini
  • 708 posts
Posted 03 February 2018 - 11:29 AM
Thanks, Local shed place built from my design. It had to get 2 cars in and offset doors for space for shelving. I had to do founds, as I didn’t want timber floor. It is evolving all the time...
Sealed walls
Extra seal on roof
Guttering ( I had dug out drainage channels prior)
Shelving
Full electrics including led light panels and sockets
New / extra locks
Price all in was a fraction of a brick built
#127 Archived1
Archived1
  • Archived
  • 619 posts
Posted 03 February 2018 - 11:42 AM
Thanks very much for the reply.
#128 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 04 February 2018 - 04:47 PM
Awesome rebuild!
Thats a long and expensive shopping list...you forgot the milk & bread!!! 😛
We want more updates, you slacker!!!
Edited by Ace Alex, 04 February 2018 - 04:47 PM.
#129 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 05 February 2018 - 01:57 PM
That is looking really good. Will you put the wooden paneling and trims back on the sides?
#130 longtimenomini
longtimenomini
  • 708 posts
Posted 05 February 2018 - 06:27 PM
What would you do?
However, I have a plan ( so cunning you could stick a tail on it and call it a fox)!
#131 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 05 February 2018 - 07:53 PM
What would you do?
I have to say I really love those old period features, I know they are rust traps ..........but
#132 longtimenomini
longtimenomini
  • 708 posts
Posted 10 February 2018 - 11:07 PM
What would you do?
There WILL be trim
#133 longtimenomini
longtimenomini
  • 708 posts
Posted 16 February 2018 - 01:17 PM
The old engine ....
Which WILL be going back in (with a few tweaks and upgrades)...for now
2nd trick engine being rebuilt... which will be .... interesting
Attached File  1510A09B-3344-4D50-97D5-1C6413B06FE7.jpeg   177.42K   3 downloadsAttached File  07B47EA7-9054-403E-A92C-3FB8870DC1CC.jpeg   176.22K   4 downloadsAttached File  A3B03A93-B323-436D-9E9D-885B8EED474C.jpeg   149.93K   3 downloadsAttached File  A8A4830D-E5A2-4C25-BA09-4F4A06A80BEA.jpeg   126.47K   1 downloadsAttached File  BA20953C-2990-4A07-85D8-3205CC1CD6F2.jpeg   124.1K   2 downloadsAttached File  1C0A7B44-95BF-4815-96BD-0D84F334139A.jpeg   123.22K   2 downloads
#134 longtimenomini
longtimenomini
  • 708 posts
Posted 17 February 2018 - 12:03 AM
This is the original engine with under 30,000 on the clock, still on leaded head. Remote gear change, 1 1/4” single carb ...
#135 longtimenomini
longtimenomini
  • 708 posts
Posted 18 February 2018 - 06:10 PM
Attached File  7B5DE485-C57E-492D-95FD-749FE6E0F6F9.jpeg   89.32K   1 downloadsAttached File  2619F9F5-683C-4B05-B30A-71EB5E6DCCB0.jpeg   82.79K   1 downloadsAttached File  E6F904E2-D8C2-47EA-AB17-7198A5576AA1.jpeg   82.77K   0 downloadsAttached File  A6929DF7-209E-436D-B8D0-81B2C562886E.jpeg   87.91K   2 downloadsAttached File  CEA42C54-B73C-4361-95E8-1BCC934E3F6F.jpeg   69.55K   5 downloadsAttached File  B01D269B-3976-4FFB-B232-A186678395C9.jpeg   91.09K   2 downloadsAttached File  4EE20640-394E-4095-B745-D39B98F3129C.jpeg   93.41K   3 downloadsAttached File  AED78259-FE3C-4E35-AABF-009BD0A7D138.jpeg   86.95K   6 downloadsAttached File  33B96CA1-32AD-457D-B6BA-075716CC6809.jpeg   86.14K   4 downloads
