1971 Lotus Inspired Clubman Estate
681 replies to this topic
#586 Quinlan minor
Quinlan minor
  • 1,169 posts
  • Local Club: LSMOC
Posted 20 March 2021 - 11:50 AM
Also Put these on mini 40 ...... well they are so good I’ll be ordering a set for estate ....so much smoother / no crashing into bumps
Where do these come from? I fancy a set for mine.
Edited by Quinlan minor, 20 March 2021 - 11:51 AM.
#587 1968andyf
1968andyf
  • 142 posts
Posted 20 March 2021 - 12:36 PM
Hydro bump stop been using them for years, more progressive than dry ones most mini parts suppliers should have them. I always use minispares ones. If your car is lowered I cut about 1/4 inch off the top on a slight angle so it meets the subframe square on
#588 longtimenomini
longtimenomini
  • 708 posts
Posted 20 March 2021 - 03:46 PM
Just found and bought another set on fleabay
NOS , will be fitting these ASAP on estate
#589 longtimenomini
longtimenomini
  • 708 posts
Posted 27 March 2021 - 05:07 PM
Bought another set of bump stops to use on estate .... I liked them so much I bought the company ! Fleabay
Getting rubbers onto mounts required lubricant , heat and the strength of a thousand men ! ..... “that’s not going in that hole!” Said the actress to the Bishop
Getting old bump stops a lot harder than the twin point mini ..... double stud put payed to a quick job.
No amount of dark magic with a spanner was going to work ....... so I released the kraken ( angle grinder) ....
Both removed with only a few grazes to subframe , which were repainted
Then I discovered the bottom pin threads were damaged , along with the inability to feed more length of the pin through as these were the built in spacer type.
So that’s where my story ends ( for now) ... ordered 2 x bolts with separate spacers ... car needs to be on his feet by next week as I have it booked in for ............ something I’m not doing
#590 longtimenomini
longtimenomini
  • 708 posts
Posted 28 March 2021 - 06:58 PM
Old bump stops that lost the battle of the kraken
Cut off painted and ready for reassemble
You can see how little thread there is on right side with the built in spacer bolt .... adding in stripped threads and that adds to problem
Edited by longtimenomini, 28 March 2021 - 07:01 PM.
#591 longtimenomini
longtimenomini
  • 708 posts
Posted 18 April 2021 - 01:53 PM
Well this went south !
Got replacement bottom pins
Cut/ Angled bump stops so they hit subframe square on
New bushes, as old ones never sat flush which shortened the useable length of thread
Then while shocks were off tested compression/ adjustable stiffness
So they both compressed and didn’t return .... and adjusting dials didn’t even change the effort to compress
This is the second set this has happened ... 1st set standard height, 2nd set lowered. 3 years old and done no more than 1000 miles
#592 imack
imack
  • 2,100 posts
Posted 18 April 2021 - 03:15 PM
I put my original one piece shock pins in the lathe and turned the spacer down by the thickness of the competition bump stop bracket.
#593 longtimenomini
longtimenomini
  • 708 posts
Posted 08 May 2021 - 07:39 AM
I need an extra garage for all the ‘big’ tools .... a lathe.... 4 post lift.... tyre changer .... and on
#594 longtimenomini
longtimenomini
  • 708 posts
Posted 01 June 2021 - 08:52 PM
Leaving 1st show .... in forever .... classic car show at witton castle on bank Holiday Monday
Great cars, great place, great weather great(ish) company .... great to be out again
#595 Maccmike8
Maccmike8
  • 1,101 posts
Posted 02 June 2021 - 08:12 AM
It looks fantastic.
#596 sonscar
sonscar
  • 2,993 posts
Posted 02 June 2021 - 08:53 AM
Looks very nice,hope we can enjoy them more,Steve..
#597 longtimenomini
longtimenomini
  • 708 posts
Posted 02 June 2021 - 10:51 AM
It looks fantastic.
Thanks , yes let’s hope this is summer we can get to many meets
#598 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 02 June 2021 - 01:00 PM
Nice drive/convoy. I found a good show for us! Set the bar high...no pressure! Great(ish) company?!...wouldn’t be the same! 😆
#599 g111mds
g111mds
  • 432 posts
Posted 02 June 2021 - 02:55 PM
That’s stunning!
#600 longtimenomini
longtimenomini
  • 708 posts
Posted 04 June 2021 - 12:43 PM
That’s stunning!
Thank you
