1971 Lotus Inspired Clubman Estate
#571
Posted 07 February 2021 - 07:21 AM
#572
Posted 07 February 2021 - 10:11 AM
If you have a stereo, link the two connectors with a 5amp fuse. This way it keeps the memory for the stereo but will blow the fuse if anyone tries to start the car due to the cranking amps.
Thank you , I don’t need a continuous feed ..... 1970’s motoring at its best
#573
Posted 07 February 2021 - 10:19 AM
Thanks for reminding me
#574
Posted 07 February 2021 - 11:49 AM
on a more practical level, does also means the interior lights will work so you can see where to insert the key if it's dark
#575
Posted 07 February 2021 - 06:01 PM
The job of shortening my battery cable that I stalled for several years has finally paid off .... cable was long enough to install cut off switch with a couple of inches to spare..... A -Team worthy !
All works ..... disconnecting battery will take seconds.
What ring terminals did you fit to the back of the isolator
#576
Posted 07 February 2021 - 06:35 PM
#577
Posted 13 March 2021 - 07:26 PM
#578
Posted 13 March 2021 - 09:30 PM
Got shape cut out ..... just playing with clocks at mo
#579
Posted 13 March 2021 - 10:34 PM
Also Put these on mini 40 ...... well they are so good I’ll be ordering a set for estate ....so much smoother / no crashing into bumps
Before
After
#580
Posted 16 March 2021 - 12:02 PM
#581
Posted 16 March 2021 - 06:20 PM
Nice idea! Are you fitting the rear ones too?
Cheers no because there’s a lot a fabrication involved and the rears don’t suffer into bumps ( far less weight)
The fronts are my favourite / best suspension upgrade I’ve made so far
#582
Posted 16 March 2021 - 10:38 PM
They look like miniature Aeon spring assistors
#583
Posted 20 March 2021 - 08:58 AM
Yes used something similar way back when - my Peugeot 405 had them , towing a trailer with a car on it , with an additional boot full of gear and 4 up in the car - let’s just say , the rear suspension worked hard !
#584
Posted 20 March 2021 - 10:41 AM
It may be the angle of the picture but where do the new bump stops bump into?The original place looks too far away.Nice car,Steve..
#585
Posted 20 March 2021 - 11:22 AM
Car jacked up wheel off and Suspension is at lowest end of drop.
It sits flat against subframe where the original stop was when back on its wheels
