1971 Lotus Inspired Clubman Estate
681 replies to this topic
#526 longtimenomini
longtimenomini
  • 708 posts
Posted 18 October 2020 - 04:28 PM
After my initial investigation
It turns out the whole tyre was flat and not just the bottom ! Ah well, I lucked out there .
Got local tyre fitter to break bead on both sides so I could dismantle and rebuild
Tiger seal the inner joint ( sorry no pic) .. then try and get tyre back on !!!!
Edited by longtimenomini, 18 October 2020 - 04:29 PM.
#527 longtimenomini
longtimenomini
  • 708 posts
Posted 24 October 2020 - 10:53 AM
Tyre back on thanks to local fitter - let’s see if this holds air , I had thought about a home tyre machine , but seeing the effort and power needed to break bead and get tyre back on with a pro machine I’m not going to bother
#528 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 26 October 2020 - 07:53 PM
A bit deflating!
You must be ‘tyre’d’ of sealing and rebuilding that wheel!
All round a wheely good job! ??
#529 longtimenomini
longtimenomini
  • 708 posts
Posted 27 October 2020 - 03:02 PM
I feel like I’m going round and round in circles rebuilding these ( might just give them away)
#530 bpirie1000
bpirie1000
  • Area Managers
  • 2,341 posts
  • Local Club: Amoc
Posted 27 October 2020 - 08:45 PM
Do you run inner tubes ?
#531 longtimenomini
longtimenomini
  • 708 posts
Posted 27 October 2020 - 09:07 PM
No inner tubes - as recommended - although over the years I have investigated / considered it as an option
to be honest I’ve been patching / resealing / rebuilding with the tyre on. It has always held for a season / year . This time is the first time I’ve had tyre off completely and sealed the inner joint ( tiger seal) , then put tyre on completely assembled wheel . I’ve always struggled with finding a tyre specialist who can get tyre off without damaging wheel ( and actually getting a 10” on a machine)
Tyre place broke bead both sides
I dismantled wheel and removed from tyre
Rebuilt and resealed inner join
Tyre place put tyre back on
This completely negates need for a tyre bar trying to pry tyre off causing damage .
#532 longtimenomini
longtimenomini
  • 708 posts
Posted 28 October 2020 - 06:28 PM
Wheels were off so had my ‘winter poke around’ ....so many jokes/ thoughts!
First off, front subframe needs another rub down and paint in (many) places - it is 50 years old !
Cleaned/ wiped inner arches , suspension etc... no major surprises until ...
Investigated the never ending hunt of oil leaks on a mini
Driveshaft oil seals ... I have bits for that as it’s been leaking for longer than I should have left them .
Weeping sump plug ... have ordered a new copper seal and a dowty rubber seal washer - will decide what to refit when I drop and change oil over winter.
And ..... this lovely hole was a surprise ! What looked like a bit of mastic stuck on/ in gear change housing turned out to be a 50 year old rubber seal that had decided enough was enough and just crumbled under my disapproving stare!
Part ordered.
#533 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 28 October 2020 - 06:52 PM
Hylamar Red on the sump plug will help with the new copper washer you have. :)
#534 longtimenomini
longtimenomini
  • 708 posts
Posted 28 October 2020 - 07:07 PM
Thanks ... I have hylomar blue in garage somewhere.... never had/ tried red
#535 longtimenomini
longtimenomini
  • 708 posts
Posted 09 November 2020 - 06:42 PM
Bits and pieces ..... shoppy shop shop
Answers on a postcard ... may have sneaked some bits into order for another mini
#536 longtimenomini
longtimenomini
  • 708 posts
Posted 21 November 2020 - 11:46 AM
Well the rebound buffer ( just one side as wheel was off) fitting took seconds ... in fact it took more time to find a long screwdriver than it did to fit it.
The gear selector rubber was a bit more of a chew as I had to drop the selector off the box ( thought I might be able to push it through from outside) .... then could I realign the bolts!!????!! Anyhoo ... all done
Other side rebound to do then , the other ‘special’ bits
#537 longtimenomini
longtimenomini
  • 708 posts
Posted 24 November 2020 - 10:16 PM
This is the time I normally put winter wheels and tyres on my ‘daily’ mini but have sold it on and the 2 remaining minis are too nice to be pressed into service over winter ..Tig youre it .....Fiat panda 100hp with steelies and winter tyres on .... bring on the snow
Will reveal/ update the early Xmas present from ABS soon. ( feel free to guess) I also have a couple of more things to buy before I start one of the winter projects.
#538 longtimenomini
longtimenomini
  • 708 posts
Posted 27 November 2020 - 03:08 PM
Other side not as bad, but worth a swap
Slight split in boot .... will keep an eye on it... will replace on next next shopping spree
While under cars .... rubber bung on backplate missing ( mini 40) ... reinstated ... with finesse
Taking bits off for next job
#539 Ace Alex
Ace Alex
  • 330 posts
Posted 19 December 2020 - 09:02 PM
Any updates?
What’s in the box from ABS???
#540 longtimenomini
longtimenomini
  • 708 posts
Posted 31 December 2020 - 11:40 AM
Thanks to Ace Alex for handmade petrol bib.
Looks great .... at my age I tend to dribble a lot
