How To Wire Main Beam Into Dipped Beam
23 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 17 October 2010 - 07:31 AM
hi i want to some how wire so when the main beam is on via the left stalk i want the dipped beam on aswell so dipped and main are on at the same time as when im on dark country roads i find that main beams isnt enough really so i have to go along holding the stalk pulling it forward so both are on. because then you push the stalk forward only the main beam part of the bulb is on?
can someone help?
thanks
josh
#2 pikey7
pikey7
  • 3,824 posts
Posted 17 October 2010 - 08:49 AM
the main beam switch is a changeover so you have one or the other. To have both would mean you were putting an incredible amount of power down titchy thin wires and through switches. You'll have an electrical fire on your hands in 5 minutes. The other thing to consider is the heat... you'll melt the headlight!
sort out the root cause first. why are your mains so weak?
#3 tedmcedd
tedmcedd
  • 2,751 posts
Posted 17 October 2010 - 08:58 AM
as pikey7 has said its not really an option... why not get some better bulbs (if you have halogens) if you dont, why not get halogens?
#4 DAVEY_C
DAVEY_C
  • 555 posts
  • Local Club: irish minis owner club
Posted 17 October 2010 - 09:04 AM
i was gonna say the same... my lights were crap till i got better bulbs.... i live up country roads too but they done the trick
#5 josh.evans
josh.evans
  • 1,439 posts
Posted 17 October 2010 - 09:11 AM
i have good headlight the wipac freeforms and some good philps bulbs it just when im on a dark road i can see much better with main and dip on
i dont think i will be doing that no more as i think your right about melting the wires =]
i suppose its just a mini thing
#6 pikey7
pikey7
  • 3,824 posts
Posted 17 October 2010 - 12:50 PM
are they adjusted properly?
#7 nicksuth
nicksuth
  • 1,631 posts
Posted 17 October 2010 - 12:53 PM
Get some extra driving lamps/spots - simples !!
#8 Wil_h
Wil_h
  • 3,244 posts
Posted 17 October 2010 - 12:54 PM
When I had a clubman with twin headlights (one main dip, one full beam) I wanted a similar effect.
I don't understand why the wiring would be a problem, the seperate elements are fed by seperate suitable wires. Not looking at a diagram I'm not 100% that they are on the same supply to the switch, but this has to be suitably rated for both, as both are on when you flash. In any case when i did it, my car never went up in flames, and I wil have considered the implications (I have a degree in electical engineering).
So, how did I do it? I basically modified the contact arrangement in the stalk, so that the dip beam did not disconnect when you pushed the stalk away (a bit of clever bending).
My worry is that you may overheat the lamp as it contains both elements, and I'm not sure I'd do it without some testing first. If I were you I'd fit some spot lights, you can get nice descreet ones these days.
#9 pikey7
pikey7
  • 3,824 posts
Posted 17 October 2010 - 01:00 PM
not worried about the feeds.. more the earths.
#10 Wil_h
Wil_h
  • 3,244 posts
Posted 17 October 2010 - 02:00 PM
Can't think how the -ve is wired on the headlamp, but it must be rated for maximum possible current, otherwise everytime you flashed someone with your headlights on they'd go off.
#11 pikey7
pikey7
  • 3,824 posts
Posted 17 October 2010 - 02:50 PM
you would imagine they would be larger than "necessary" yeah. I doubt they could cope long term though. Mini wiring seems borderline at the best of times!
#12 Cerberus
Cerberus
  • 989 posts
Posted 17 October 2010 - 04:04 PM
Its not really just a mini thing.
I had similar issues with my fiesta. I got some halfords brighter bulbs and it helped. Aligning the headlights helped more though.
I would imagine some spots would help though, and not ruin your headlights, =]
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 October 2010 - 04:23 PM
I'll check the regulations but I'm fairly sure it's also illegal, as well as potentially dangerous. If you wanted to do it you should employ a relay to power the dipped beam while the main is on because the latching side of the dip switch connects both circuits to the same source. The dip switch cannot run 230 watts without suffering.
Time is a factor. The earth cable is the same size as each of the supply cables. As you suggest, heat would be the major problem and would eventually destroy the lamp.
Fit spot lamps.
#14 josh.evans
josh.evans
  • 1,439 posts
Posted 17 October 2010 - 04:38 PM
lights are set to mot standard. i think the heat would cause problems as the wipacs are plastic fronted :(
#15 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 18 October 2010 - 05:19 AM
You know what you need Josh?
You need some of these you do !!
