Gearbox Case Broken
9 replies to this topic
#1 Barman
Barman
  • 1,068 posts
Posted 14 October 2010 - 10:52 AM
Hi again guys,
Just cleaning my engine prior to a re-build and under the muck and mess I discovered this broken fitting: -
It is the bracket that holds the rod change steady rod to the gearbox.
How serious is it?
Can I use it in this condition?
I don't have the bit that fell off so I can't weld it back on or anything...
[EDIT] It is actually on the diff housing but somebody (on here) mention that the diff and gearbox where machined as a matched pair and couldn't be separated.
Edited by Barman, 14 October 2010 - 10:58 AM.
#2 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 14 October 2010 - 11:06 AM
Either get it built up with weld (5% silicone rod) or replace the case are your only options
Paul
#3 Barman
Barman
  • 1,068 posts
Posted 14 October 2010 - 11:32 AM
Paul
Thanks Paul...
I have as much chance of getting it welded here (Cyprus) as I have of flying to the moon this arvo...
A new case it is then...
#4 Ethel
  • 25,809 posts
Posted 14 October 2010 - 11:42 AM
Surely there must be someone there who can weld aluminium??? RAF/Army workshops; dairy, refrigeration or air conditioning companies?
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
From you mail I thought it was completely broken, that I would put a new bush in and it will probably hold for many years, It's not there in a support role like and engine steady or mount, it's just to maintain a constant distance between the gearbox and the remote unit.
#6 Barman
Barman
  • 1,068 posts
Posted 14 October 2010 - 11:49 AM
Excellent, thanks!
#7 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 14 October 2010 - 11:51 AM
Actually if you cleaned all the gink out of there and stuck some sort of epoxy in there it would help too.
#8 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 14 October 2010 - 12:30 PM
Guess Works to the rescue! :-
#9 Ethel
  • 25,809 posts
Posted 14 October 2010 - 12:32 PM
or try this stuff if you can lay your hands on some oxy acetylene kit.
#10 Barman
Barman
  • 1,068 posts
Posted 14 October 2010 - 05:39 PM
Thanks for all your inputs guys... this forum is a life saver...
I decided that, as I have the whole car in pieces (and was going to rebuild the engine/gearbox anyway) to buy a new gearbox/diff housing from Guess-works (at an amazing price) and do it all properly... I've already spent €9,000 on the damn thing...
