Mk3 Saloon, Very Rusty Project
879 replies to this topic
#751 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 13 June 2013 - 06:55 AM
is there any particular reason you went for 13's and not 10's? im just curious.... does look nice with the arches tho
cheers james
 The reasoning for the general spec. of the car is to have bits & pieces that I couldn't get when I was doing minis years ago. Coil spring suspension for instance. I wanted big wheels back then & 12" were very hard to get & 12" tyres virtually impossible. The choice now is vast & cheap! I've liked the 13" wheels since Rover started putting them on. Racers were using them a long time ago too. 10" wheels are very popular at the moment. 20 years ago you couldn't give them away. I run a set of 12" on another mini & the next project will have 10", so just different wheels for different styles.
#752 jagman.2003
jagman.2003
  • 1,307 posts
Posted 13 June 2013 - 07:33 AM
A small success to many but a major triumph for me. As previously mentioned the rear plate light plinth was causing me alot of grief. Mainly due to paint reacting. I ended up painting two of them at the same time to increase likelihood of success. Got there in the end & bolted one on last night. Light bulb holders are a bit of a dubious design & one will need fettling to work reliably. But looking good now. I think that's the rear end done for now. Will be working my way forward to finish everything else off.
Edited by jagman.2003, 13 June 2013 - 07:34 AM.
#753 jpw1275
jpw1275
  • 2,803 posts
Posted 13 June 2013 - 08:51 AM
cheers james
ah gotcha... i had 12's on before the 10's... so i changed to cooper s discs for my white mamba's but now ive gone for cooper s wheels from minisport where i could of kept the 8.4" discs as they fit!!!! ... are you badging up on the rear or keepibg it nice and simple? i think im just having an austin badge above the number plate light... you say small tasks but they all add up buddy..;0)
cheers james
#754 jpw1275
jpw1275
  • 2,803 posts
Posted 13 June 2013 - 08:59 AM
im in the middle of welding the rear end up.. ( boot floor, hinge panel, rear valance, rear arches , lower quaters near the bumper, closure plates... then onto the sills and floors i think.... only working on it on sundays so its taking ages but il get there..
cheers james
#755 jagman.2003
jagman.2003
  • 1,307 posts
Posted 14 June 2013 - 07:19 AM
Seat belts fitted last night. Used a set from Minispares which came with a selection of bolts & brackets. I did have to buy some longer bolts for the inertia reels to the rear pockets. (7/16" unf x 2"). Also packed the reel out slightly as it fouling the pocket & wouldn't retract fully. But all in now. The left over brackets for the belts will come in handy elsewhere. Mounting the horns for instance..! Just got to clean up the seat retaining brackets that bolt through the floor & the front seats are ready to go in.
Edited by jagman.2003, 14 June 2013 - 07:21 AM.
#756 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 15 June 2013 - 07:32 PM
You are moving along and it looks so good. Your paint is wonderful.
Hugh
#757 JacckKirk
JacckKirk
  • 889 posts
Posted 17 June 2013 - 08:37 PM
Woow .. Just read through from start to finish and just gotta say well done
Motivated to get on with mine now
#758 jagman.2003
jagman.2003
  • 1,307 posts
Posted 20 June 2013 - 10:46 AM
Thanks, glad my project has been of use to others.
#759 jagman.2003
jagman.2003
  • 1,307 posts
Posted 20 June 2013 - 10:47 AM
Hugh
 Thanks Hugh, yes the light at the end of the tunnel is real for me now. The paint didn't work out bad. Learning all the time for the next one!
#760 jagman.2003
jagman.2003
  • 1,307 posts
Posted 26 June 2013 - 07:29 AM
This week so far I have fitted the steering column properly. Also the indicator stalk & cowling. Looking alot tidier inside now.
#761 jagman.2003
jagman.2003
  • 1,307 posts
Posted 28 June 2013 - 07:34 AM
Front carpet in, heater finally wired & screwed in place. Floor brackets for seats bolted in. I've dug the seats out & I'm putting the subframes on in the living room. I have found with classic buckets in the past that a small spacer at the rear of the drivers seat just puts them at a nice angle. I'm looking at fitting some nylon spacers between the seat & subframe. Photo later on today.
#762 jagman.2003
jagman.2003
  • 1,307 posts
Posted 28 June 2013 - 11:59 AM
Photo as promised.
#763 jagman.2003
jagman.2003
  • 1,307 posts
Posted 08 July 2013 - 08:12 AM
New roller rockers. 1.3 ratio. Had a set of sintered ones on before, which worked fine. But time for an upgrade.
Also new rocker cover. The old one had been faithful but needs a good polish. So to give the engine a little facelift I have got this one from Minits. It was listed as black wrinkle finish. But it's more like a hammered grey/silver. But I kinda like it. I need to check the clearance with the bonnet before deciding where to refit the breather. Also had to grind some notches in the flange for the two extra studs.
Edited by jagman.2003, 08 July 2013 - 08:13 AM.
#764 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 08 July 2013 - 03:53 PM
Wow. Too good jagman.2003.  I'm really looking forward to the video of you taking it out for a wee spin.
Hugh
#765 jagman.2003
jagman.2003
  • 1,307 posts
Posted 09 July 2013 - 08:03 AM
Hugh
Thanks Hugh, Struggling to get much time at the moment, but the list is getting shorter.
    Bing (1)
