Mk3 Saloon, Very Rusty Project
879 replies to this topic
#691 ba-tat
ba-tat
  • 53 posts
Posted 26 April 2013 - 04:11 PM
You've got to try and take a picture of the Mini alongside the picture from Post Number 3 of this thread. Even could you do it in the same place?
It would be hilarious to see the before and after at the same angle.
#692 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 27 April 2013 - 08:46 PM
You are so good!!! I just wish I could do it right. It just look so nice.
Hugh
#693 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 29 April 2013 - 07:10 AM
Yes, could be fun. I can park in the same place or even do a little photo shop side by side.
#694 jagman.2003
jagman.2003
  • 1,307 posts
Posted 29 April 2013 - 07:15 AM
Hugh
Thanks Hugh, it is coming together at last. I'm sure you'll get an excellent result with yours.
#695 jpw1275
jpw1275
  • 2,803 posts
Posted 30 April 2013 - 09:15 PM
what a fantastic read and job.... top work mate
cheers james
#696 jagman.2003
jagman.2003
  • 1,307 posts
Posted 01 May 2013 - 07:54 AM
"what a fantastic read and job.... top work mate
cheers james"
Thanks James, coming together nicely now.
#697 jagman.2003
jagman.2003
  • 1,307 posts
Posted 01 May 2013 - 08:05 AM
Mid week update. Have taken the dashboard out again. Hopefully for the last time. Just finishing any wiring that is required behind it. I found indicator flasher unit connections. Checked wiring supply for heater blower. Found a lose connection that was stopping me having two speed wipers. The car originally only had single speed (at least they park). But as the wiper switch needed replacing I went for a two speed one. The original wiper motor got pinched by me a long time ago. So I got a late second hand replacement at an auto jumble. All I did was run another wire from the back of the switch to spare connection on the motor & voila! Two speeds! With park. I need to get the fresh air vents connected. Been a bit tricky getting some ducting flexible enough. I should have put the vents slightly lower in the dash. But I don't fancy making another dash front if I can help it. I also need to angle the gauge pod up slightly. So as I have some spare gauge frames then I might see if I can modify one of those to get the angle I want. All will hopefully become clear later. I'm also starting to eye up the rest of the body panels. Boot, bonnet & doors. They still need prepping & paint.
#698 markje
markje
  • 183 posts
Posted 01 May 2013 - 04:28 PM
Wiring can sometimes be a  pain in the butt
#699 jagman.2003
jagman.2003
  • 1,307 posts
Posted 02 May 2013 - 07:25 AM
Certainly can be, but a mini is as simple as it gets really. So hopefully this shouldn't be too much of a challenge.
#700 markje
markje
  • 183 posts
Posted 02 May 2013 - 04:55 PM
True,gladly no injection computers an that sort of stuff
#701 jagman.2003
jagman.2003
  • 1,307 posts
Posted 13 May 2013 - 07:43 AM
Quick weekend update. Not much of excitement happening at the moment compared to the test drive. It's back to the list of little jobs that need to be done to move on. Just one thing for anybody who is interested. The fuel pump was still leaking slightly. It was removed & the fittings tightened as much as I dare with brass threads in a vice. Seems to have done the trick. Anyone who has been reading this thread recently will know the first set of rubber pump mountings failed. It seems the leaking petrol destroys the rubber bonding as the second set failed as well. I have now used some M6 rubber exhaust mounts from ebay. They are slightly taller but seem stronger. Also this weekend I routed some wiring for the rev counter. Then looked at the lower engine steadies. My mini of old would occasionally pull the exhaust off just after the LCB due to the engine moving on hard acceleration. So I'm securing this engine in all directions. I've fitted the passenger side & just need to drill a hole for the drivers side dog bone. Plenty of odd jobs left, but coming together slowly.
#702 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 13 May 2013 - 12:32 PM
As always its the little tidying up jobs that seem to take the longest! Chin up, nearly there ;o)
#703 jagman.2003
jagman.2003
  • 1,307 posts
Posted 14 May 2013 - 07:11 AM
I'm trying not to shy away from them as well. As they come back to haunt you at MOT time. Ooooh I have indicators now as well.
Edited by jagman.2003, 14 May 2013 - 07:12 AM.
#704 jagman.2003
jagman.2003
  • 1,307 posts
Posted 20 May 2013 - 07:22 AM
Got some good time in on the mini this weekend, but didn't seem to get that far. Must be due for a leap forward next weekend. Completed fitting the lower engine steadies. Spent some time sorting out some paint in various places. Also fitted the new throttle linkage. Same make as before Mangoletsi. The old one had some wear on the main spindle. This one seemed to work & give full throttle with standard out of the box settings. So that was handy. But when I fired it up to test the engine coughed & blew an o-ring out of the carb joint..! Must've been all my fiddling with the carb that left too much fuel in the inlet. But should be a quick fix. Might need some new o-rings if in anyway damaged. Other than that linkage worked well. Could do with a little more spring tension. Will have to see if there is any adjustment there.
Edited by jagman.2003, 20 May 2013 - 07:23 AM.
#705 wolfie
wolfie
  • 1,149 posts
Posted 20 May 2013 - 07:40 AM
Might be a bit late but slarks is the only RR i use now, not saying what others use is bad but they have been the best for me
