Mk3 Saloon, Very Rusty Project
#616
Posted 14 January 2013 - 07:40 PM
#617
Posted 14 January 2013 - 08:15 PM
#618
Posted 15 January 2013 - 08:24 AM
Brilliant progress! Loving it!
As for carbon wrapping, use water with abit of washing up liquid on the item being wrapped, preferably out of a spray bottle, mist it 1st and a filler spreader helps to smooth any air bubbles, the water/washing up liquid helps the wrap slide without sticking until the water evaporates! use a heat gun to soften it a little as you wrap, and keep it tight, less wrinkles, better finish!
Thanks for the tips. The wrap didn't come with any instructions. I did try some water but because I was impatient & hadn't painted the mdf it just soaked straight in. Will try that on the next piece, cheers.
#619
Posted 15 January 2013 - 08:25 AM
Thanks, the white really does look nice..!Still a fantastic read keep going -love the colour!!
#620
Posted 15 January 2013 - 08:26 AM
Thanks, it certainly isn't the same floppy box of rust.what a transformation! looking good!
#621
Cheers, light at the end of the tunnel as well....nice work mate
#622
Posted 15 January 2013 - 09:06 AM
One thing to think about if you're wrapping the MDF is that it is incredibly porous. Any flat surface that you haven't sanded will be fine, but cut edges and any surface that you sanded will soak up water and adhesive like nobodies business. It would be worth sealing the MDF with some MDF sealer first. May need a couple of coats and a very fine sand/ wirewool before wrapping. HTH
#623
Posted 15 January 2013 - 06:03 PM
#624
Posted 16 January 2013 - 08:07 AM
No problem, all opinions taken on board. I agree the carbon wasn't my first choice. Although I didn't want to just paint the MDF. Thought it would definitely look home made. I tried wrinkle finish paint, which would have been a bit more of a classic look. But I couldn't get a very consistent finish with it. I'm just trying the carbon for now. All other ideas welcomeWell its not my taste the carbon bit,Sorrry but i am still liking the classic style hover its a great job you ve done
#625
Posted 16 January 2013 - 08:19 AM
Maybe a disctreet purple or similar wrap to break up the theme abit.
#626
Posted 16 January 2013 - 03:22 PM
How about machine finished aluminium plate with some crinkle finish portions?Hmm not sure of what else you can do to mdf apart from wrap it,because as you said the finish would look rough.
Edited by PipeNslippers, 16 January 2013 - 03:23 PM.
#627
Posted 16 January 2013 - 05:01 PM
http://www.restaurat.../fineerwerk.htm
on this site unfortuante its Dutch but you can see if you scroll down a dashbord wich is at firts from normal wood and the second photo the same but with a walnut layer on it< I hope i made things clear :)
#628
Posted 16 January 2013 - 09:09 PM
#629
Posted 17 January 2013 - 08:02 AM
Thankyou for your input Mr.Slippers. I had thought about aluminium. But went for the MDF as it's easier to work with. The shape is very labour intensive. Also I was worried anything too bright & shiny might reflect in the sun. (not that we get much of that).How about machine finished aluminium plate with some crinkle finish portions?
#630
Looks very nice.Well you can how does it calle in the uk Verneer it.. just use a thing piece of wood an glue or ironing it it on the MDF
