Mk3 Saloon, Very Rusty Project
879 replies to this topic
#46 minidream94
minidream94
  • 1,233 posts
Posted 30 October 2010 - 07:39 PM
fancy coming and doing mine for me mate :thumbsup:
respect for taking this project on, just means there yet another mini that will soon be roaming the roads of britain :dontgetit:
best of luck mate ;)
#47 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 31 October 2010 - 06:55 PM
A bit more done today. New o/s rear wheel arch in.
Still need to do the full plug welding underneath later when the shell gets rolled over.
#48 minimikej
minimikej
  • 347 posts
Posted 02 November 2010 - 09:41 AM
Hi, fascinating project! Worse than mine even.
I'm in a similar position with my boot floor and wheel arches, how did you ensure that the arches are lined up correctly without the rear quarters for reference? Or is it a case of using 'original construction techniques'? :thumbsup:
Cheers -
Mike
#49 jagman.2003
jagman.2003
  • 1,307 posts
Posted 02 November 2010 - 10:45 AM
Cheers -
Mike
Hello Mike, I've lined up the arch using the boot floor & squab board mainly. The squab board is pretty much where it was with the old arch as I was able to drill out the spot welds. The new boot floor is fairly close to the profile of the arch so took only a small amount of jiggling & cursing. I clamped the arch first & then offered up the quarter panel & the closing panel infront of the arch. I have left the passenger arch in for reference so I also ran a spirit level across the tops of the arches to check height. Hopefully that should be somewhere handy. I'm happy with the result so far. The rear panel should be going on this weekend after a couple of other small bits. Good luck with yours Mike.
#50 jagman.2003
jagman.2003
  • 1,307 posts
Posted 07 November 2010 - 07:28 PM
Weekly update. Got the squab repair done, not the prettiest but nice & solid. Inspired by 'Project Erm' repair. But probabaly without the fabrication skills they used. The drivers side wheel arch to squab bracket was then welded in. This left the squab panel rigid enough to remove the parcel shelf. I was going to try & save the parcel shelf but the rear accident damage had left it slightly bent & subsequently a few large rusty holes had formed. As I was keen to get any alignment back I had to discard the bent shelf. I offered up the rear panel earlier in the week & marked out all the final cuts. So the panel I've been dying to attach since I bought it is the rear panel. the mini has finally got it's round butt back after 20years of a crumpled bottom! Next week, drivers door frame & quarter panel.
#51 jagman.2003
jagman.2003
  • 1,307 posts
Posted 14 November 2010 - 09:50 PM
Weekly update, finished welding the rear panel along the boot floor. Welded in the boot to squab/seatbelt bracket. The fun bit for the weekend was fitting the new lower door frame on the drivers side. It's the heritage all in one lower frame. So getting the right angles isn't so difficult. I kept the inner wing door hinge bolt holes, so was able to comfirm alignment of the door post.
#52 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 14 November 2010 - 10:00 PM
I wish mine moved along as quickly as this
Good luck mate
#53 jagman.2003
jagman.2003
  • 1,307 posts
Posted 15 November 2010 - 08:36 PM
Good luck mate
Thanks, I have employed the 'ignore everything else' method to find time to get it done. Hopefully I'll be able to keep up the progress.
#54 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 15 November 2010 - 09:09 PM
Good luck mate
Thats a rule I wish my dad would take on board. Good luck mate , another mini near its death that will be restored , will be nice to compare :D
How long you reckon it'll take mate?
#55 jagman.2003
jagman.2003
  • 1,307 posts
Posted 15 November 2010 - 09:22 PM
Good luck mate
Hoping to have the basic shell complete by Christmas. Then use Christmas break to get some final fettling or catching up.
#56 jagman.2003
jagman.2003
  • 1,307 posts
Posted 21 November 2010 - 09:00 PM
Weekly update, decided to change the plan. Was gonna work on the front end but looked at how little the floor was now doing & how much the lack of inner sills was holding up other areas. So a few careful cuts & the floor was out. Ran out of time to get the new floor in this weekend but got the floor cross member welded up. Just gotta add the seatbelt mounts & the jacking points. Also a little bit more tidying up the shell.
Edited by jagman.2003, 21 November 2010 - 09:50 PM.
#57 Pending
Pending
  • 522 posts
Posted 21 November 2010 - 09:08 PM
hats off to you feller, cracking on well,
may i ask why you've chosen the later parcel shelf to a mk3 one
#58 jagman.2003
jagman.2003
  • 1,307 posts
Posted 21 November 2010 - 09:57 PM
Thanks for the comment. I couldn't see any other options for the parcel shelf available. I didn't mind the later one it's alot straighter that the original & has the speaker holes if I want to use them. I can always blank them off if I don't want to use them.
#59 Pending
Pending
  • 522 posts
Posted 22 November 2010 - 07:24 PM
fair do's, thought it was something like that
#60 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 25 November 2010 - 04:19 PM
I have got to say you are doing really well rescuing this and so far so good. :thumbsup:
