Looking forward to seeing those wheels. I do like wheels & how they finish a car off.
nice one, love those shiny wheels, got to fit mine on MUK next Monday,.....look forward to that...
I fitted the arches on Monday
Posted 04 July 2012 - 12:17 PM
Posted 04 July 2012 - 09:09 PM
Posted 12 July 2012 - 07:34 AM
Posted 12 July 2012 - 06:06 PM
Posted 13 July 2012 - 07:14 AM
Thanks, much appreciated.You are very talented, well done
Posted 13 July 2012 - 07:15 AM
Thanks, I'm keen to see it finished too..!Really enjoyed reading this project can't wait to see the finished Mini!
Posted 13 July 2012 - 07:20 AM
Posted 13 July 2012 - 11:01 PM
Still working on the brakes this week. Have partial pedal. Just going round eliminating possible causes. Still not sure if it's air or adjustment type issues. Have one new arch fitted & another painted ready for a polish.
Posted 14 July 2012 - 12:21 AM
Posted 14 July 2012 - 09:36 PM
Posted 14 July 2012 - 09:52 PM
good point Scott....Don't forget brake fluid is hygroscopic, which means it absorbs moisture from the atmosphere. Short periods are ok, but leaving the cap off for too long could absorb moisture that could corrode the internals of components. New bottles of fluid have a foil seal to prevent moisture ingress and so also have a limited shelf life when opened. .
Posted 15 July 2012 - 06:35 PM
Posted 16 July 2012 - 07:11 AM
Thanks, I'll give this a go. My theory is at the moment that the master cylinder (0.7") bore isn't moving enough fluid for a single line system. I have the larger bore rear slave cylinders & minisport four pot calipers on the front. I'll try every beeding method going, but I am ultimately looking at changing the master cylinder for something with a bit more piston capacity. I see on here some people have used a clutch master cylinder (0.75"). I'm looking at going for a 7/8" (0.875) bore girling master cylinder with remote reservoir. But will exhaust all options first.
brakes bleeding,...bleedin brakes.....I would suspect still air somewhere, same with all new fill-up's, I had the same with MUK, in the end I let gravety just do it's thing, one brake at the time, attach clear hose and open brake nipple a lttle, put through a hole in the lid into jam jar with little brake fluid in the bottum(vacuum), then top up master cylinder and leave the top off, gravety will do the rest, just keep and eye on it now and then and see if any air is pushed through the hose, and if master cylinder needs topping up.
I am sure yr thinking, why is he telling me all this........
Edited by jagman.2003, 16 July 2012 - 07:16 AM.
Posted 16 July 2012 - 07:12 AM
Thanks, I'll make sure not to leave it open too long. Especially with all this rain in summer.Don't forget brake fluid is hygroscopic, which means it absorbs moisture from the atmosphere. Short periods are ok, but leaving the cap off for too long could absorb moisture that could corrode the internals of components. New bottles of fluid have a foil seal to prevent moisture ingress and so also have a limited shelf life when opened. .
Edited by jagman.2003, 16 July 2012 - 07:14 AM.
Posted 16 July 2012 - 07:14 AM
Hello Mike, when the limiter closed did it stop all fluid coming through? I have had no problems so far getting fluid out of the rears. Just don't seem to have a very good pedal. Almost hits the floor first go, then second go it comes up better.
Hi, If you are having trouble bleeding on a system with the rear brake limiter valve, I can sympathise. I tried with an easy-bleed and failed, and even with a traditional 2 man bleed we got nowhere at first. You have to be very gentle on the down stroke to avoid closing the brake limiter valve. If that locks off at all you won't be able to bleed anything on the atnospheric side of it.
Edited by jagman.2003, 16 July 2012 - 07:24 AM.
