Mk3 Saloon, Very Rusty Project
879 replies to this topic
#286 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 20 October 2011 - 08:58 PM
Quick update. I've been working on the rear subframe & suspension. I was hoping it would come together as quick as the front but it's fighting me a bit. I've been cleaning & painting lots of bits. The original subframe was stripped of all parts & the dust left behind swept into the bin. I've started flatting back the paint inbetween as well. More updates this weekend.
Edited by jagman.2003, 20 October 2011 - 08:59 PM.
#287 minimuk
minimuk
  • 1,947 posts
Posted 20 October 2011 - 09:38 PM
And now the fun begins, good luck I am sure you make it perfect!!Just don't do any rush jobs, aint worth doing. ;D
#288 BusheyTrader
BusheyTrader
  • Just Joined
  • 484 posts
  • Local Club: Nope
Posted 21 October 2011 - 07:42 AM
I've enjoyed reading all the updates......
I read somewhere that a Mini is basically two subframes joined together by a large bracket. That's some bracketwork.
Adam
#289 jagman.2003
jagman.2003
  • 1,307 posts
Posted 30 October 2011 - 09:06 PM
Still polishing the paint, almost got all the way round. Looking forward to bolting things on soon.
#290 Risky
Risky
  • 213 posts
Posted 30 October 2011 - 11:05 PM
Looks good. Is it hard to paint a mini?
Edited by Risky, 30 October 2011 - 11:05 PM.
#291 jagman.2003
jagman.2003
  • 1,307 posts
Posted 31 October 2011 - 08:16 AM
Thanks, not that hard to paint. It's not a big car. Get's a bit more work when your doing the whole shell like mine. Lots of fiddly bits to work on, but not many big flat areas to cause grief.
#292 Risky
Risky
  • 213 posts
Posted 31 October 2011 - 08:28 PM
Thanks for the reply, it's only the outside of my shell that could use a repaint on some area's. I'm thinking about doing it myself to keep the costs down
#293 jagman.2003
jagman.2003
  • 1,307 posts
Posted 01 November 2011 - 08:36 AM
It's not that difficult to do some touch ups or a blow over. But as ever it's the preparation that counts. Worth looking at the posts on the tech forum here to get an idea of what's needed. You can polish up a bad spray job but not if it's sprayed on a ploughed field.
#294 g111mds
g111mds
  • 432 posts
Posted 01 November 2011 - 12:23 PM
fantastic project and progress! (just read from the start) :)
#295 jagman.2003
jagman.2003
  • 1,307 posts
Posted 01 November 2011 - 01:03 PM
Thanks, hopefully on the home straight now.
#296 jagman.2003
jagman.2003
  • 1,307 posts
Posted 04 November 2011 - 08:50 PM
Main part of a new wiring loom run through the roof rail. Luckily I rememberd to run some wire through when I removed the old loom to feed the new one back through. I think I've worked out where the rest goes. Helped by the trusty haynes manual wiring diagram. If only all the colours matched up.
More to come this weekend.
#297 minimuk
minimuk
  • 1,947 posts
Posted 05 November 2011 - 06:32 PM
nice colour, nice work, you do have patience that's for sure.
#298 jagman.2003
jagman.2003
  • 1,307 posts
Posted 06 November 2011 - 06:42 PM
Some more jobs done this weekend. Waxoyl & cavity wax applied to the shell. Some more work on the loom. The wiper motor, mechanism, blanking plugs & washers fitted. Nice to fit a few bling bits. Might try & find a better wiper motor cover. Also wasted some time looking for the parts I needed. But hopefully I've found all the bits I'll need later. More cleaning painting & fitting next week.
#299 minimuk
minimuk
  • 1,947 posts
Posted 06 November 2011 - 07:18 PM
one thing I have learned with finishing a mini, got to have patience and plan ahead, specially fitting old things back who would be better replaced with new ones in the first place, and fitting bits, washers,bolts,nuts,self-tappers,spring washers,etc, you got to have enough of those bits,...plan ahead, otherwise it is stop-start-stop-start all the way. same with the electrics, get your crimping set with all the connector bits you might need before you start that.I don't know why I am telling you this, you probably have sorted all this already.
enjoy the ride to the finish line ;D
#300 jagman.2003
jagman.2003
  • 1,307 posts
Posted 06 November 2011 - 08:02 PM
Thanks, your right. I thought I had it all covered but the first things I fit I'm missing or lost some parts. I even pinched some bits for other cars & forgot..! No doubt despite much planning I will still be ordering rush parts. The only thing that's helping right now is I've made a list of jobs I can do for the next couple of weeks. So I can always refer to that if I'm held up & still move on. Thanks for the advise again.
If anyone else reading this has done the main loom before. Does the purple & white wire for the r/h door switch run over the top of the windscreen?
