Raf Blue 1600 K Series
#31
Posted 08 January 2011 - 08:45 PM
ill get pictures up tomorrow.
#32
Posted 16 January 2011 - 10:26 PM
need some new fuel line a filter and a pump, and i can run it up!
gonna de bumber the rear at somepoint this week fingers crossed.
#33
Posted 31 January 2011 - 05:27 PM
#34
Posted 31 January 2011 - 06:34 PM
Whilst the tank was out, I thought I might aswell get on with the debumpering ive been meaning to do for years.
I thought it would look funny having a debumberd clubman front.
and a rear curvy mini bumper, so ive chopped it off and welded it up.
Hm, BOOTIFUL!
#35
Posted 09 February 2011 - 04:41 PM
got the coolant plumbed in,
ive got one heater pipe going to the cylinder head, and the other going to the thermostat housing.
the main pipe from the header tank goes to the take off in the pipe from the thermostat.
and with a T peice from the top of the header tank one pipe goes to the inlet, and the other goes to the rad. Does all that sound about right?
another problem i have found is the little clearance with a master, ive been thinking of two things, one tilt the master back a few degrees to clear the inlet a tad more. or grind the corner of the master back?
it does clear it but its less than a mm, and even though my engine is nearly solid i think it will still hit it under hard acceleration.
I know this may be frowned upon but can i remove some of the material circled below?
Also does anyone have any pictures of their mini cable clutch pedals and where/how they locate on the bulkhead?
#36
Posted 09 February 2011 - 04:46 PM
#37
Posted 09 February 2011 - 04:51 PM
Top work there Liam, subscribed for updates....
Aye up, regarding the milling work,
ive been off work all week so i have not checked my emails yet. ill get back to you end of the week unless youve got someone else to do it.
#38
Posted 09 February 2011 - 07:16 PM
#39
Posted 09 February 2011 - 07:30 PM
Iv cut that part off my manifold...
Really? the tubular bit for each inlet port?
#41
Posted 21 February 2011 - 11:57 AM
#42
Posted 21 February 2011 - 11:59 AM
Edited by CaptainBland08, 21 February 2011 - 12:04 PM.
#43
Posted 27 February 2011 - 02:07 PM
new knuckle joints, re hung my drivers door. some more work DA'ing the rear bumper, bolted passenger seat back in.
loads of little jobs.
oh also found these.
and....
#44
Posted 27 February 2011 - 04:41 PM
racing line
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/teehee.gif)
#45
Posted 27 February 2011 - 06:39 PM
