Raf Blue 1600 K Series
325 replies to this topic
#256 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 10 September 2015 - 08:14 PM
Are you running lowered shocks or standard?
If standard, I'd suspect that running so low has killed them off.
#257 Broomer
Broomer
  • 1,771 posts
Posted 10 September 2015 - 08:27 PM
Lowered shocks. I did think it was strange that when jacked up the radius arm dropped right down allowing the Hilo and rod to rattle around. You Can lift the wheel up and down with no dampening.
But only on the Jack's at droop, on the road it doesn't seem terrible, except the previously mentioned wondering at high speeds.
#258 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 10 September 2015 - 08:50 PM
my gaz lowered ones droop up and down a little bit when on stands, seem fine on the road, I thought it was normal haha.
#259 leaky
leaky
  • 6,890 posts
Posted 10 September 2015 - 09:32 PM
Not read this in ages, car looks awesome now man!
#260 RossKnight
RossKnight
  • 2,539 posts
Posted 10 September 2015 - 10:51 PM
it's bloody quick too.
#261 Broomer
Broomer
  • 1,771 posts
Posted 12 September 2015 - 05:46 AM
I am tempted to build up a nice 1800 with sporty cams and throttle bodies etc for a few more ponies. Or maybe a vvc or turbo motor ? Who knows.
#262 RossKnight
RossKnight
  • 2,539 posts
Posted 12 September 2015 - 11:09 AM
You've got that spare 1800 block don't you? Stick nice cams in it Tbs
#263 Broomer
Broomer
  • 1,771 posts
Posted 20 September 2015 - 09:27 PM
The difficult part is parting with like, 1500/2000 quid to build the cammed / throttle bodied engine when I'm used to 100 quid engines.
#264 Broomer
Broomer
  • 1,771 posts
Posted 22 September 2015 - 02:19 PM
Turns out my front suspension is sat on the bump stops, I'm hoping its that which was making it handle odd.
#265 RossKnight
RossKnight
  • 2,539 posts
Posted 22 September 2015 - 03:37 PM
Yeah that'd do it... Wound it up or cut the stops?
#266 Broomer
Broomer
  • 1,771 posts
Posted 22 September 2015 - 05:58 PM
Stops already cut in half.
#267 Broomer
Broomer
  • 1,771 posts
Posted 22 September 2015 - 09:00 PM
I am also rebuilding a land rover, the tires turned up today.
#268 Broomer
Broomer
  • 1,771 posts
Posted 25 September 2015 - 10:28 PM
Even though I cut my bump stops down to 22mm it turns out my car was sat on them. I am thinking this may explain the twitchy handling. Today I have raised the height 20mm, and applied more castor and slightly more camber in preparation for castle combe tomorrow.
Fingers crossed it handles OK.
#269 Broomer
Broomer
  • 1,771 posts
Posted 25 September 2015 - 10:30 PM
Also whilst re shimming a ball joint I managed to pop a drive shaft out dumping the thousand mile old oil onto the floor, doh!.
#270 Broomer
Broomer
  • 1,771 posts
Posted 27 September 2015 - 11:34 AM
Made it to combe and back (180 mile round trip) as well as two track sessions.
Went OK, suspension setup seems 95% there now.
If any one has any pictures that would be great.
I did film the first session but it was not that interesting.
