Backfire Through Carb/no Power?
25 replies to this topic
#1 penfold38
penfold38
  • 215 posts
Posted 09 October 2010 - 05:52 PM
Mini Clubman 1275 GT, 1979.
Engine 1293cc
Sportex Exhaust
Hs4 carb.
Recently finished the rebuild on my 1275 GT.
It passed its MOT fine,but the tester said he had to weaken the mixture on the carb to get it through the emissions test,but ran like a bag of spanners popped and backfired through the carb all the way home,and lacked anypower when i put my footd down,he told me to rebuild the carb so i did.
I made a note of the tag on the carb phoned carb company they told me the carb was of a Austin 1300 1971-72??, anyway ordered the parts rebuilt and put it back on starts ok and idles fine,but still backfires and just no power or acceleration takes an age to get to 30mph!!!!,and when you floor it nothing happens slow and pops and bangs through the carb...........also it did run after turning off,this was after i tried to enrichen the carb.
Just to point out everything on the engine is new full rebuild.
my own fault really gone this far with the rebuild should of gone for a new/recon carb.
I have been offered a HIF 38 would this be a good replacement.??
Edited by penfold38, 09 October 2010 - 05:53 PM.
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 09 October 2010 - 06:38 PM
Is the intel manifold/gasket leaking?
#3 penfold38
penfold38
  • 215 posts
Posted 09 October 2010 - 06:55 PM
It doesnt seem tobe leaking,but will check tomorrow, i'm sure its the carb.
May try this HIF38.
#4 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 09 October 2010 - 07:13 PM
Cheaked Timeing? or has it been timed up properly
#5 penfold38
penfold38
  • 215 posts
Posted 09 October 2010 - 07:16 PM
Yep timing was checked and corrected using a strobe/light.
I just want to get it going..!!!.....properly.
#6 me madjoe 90
me madjoe 90
  • 1,238 posts
Posted 09 October 2010 - 07:22 PM
Who knows hard to fault find with out it being in front of you to play with.
some one hear will give u some good advice good luck hope you get it sorted
#7 penfold38
penfold38
  • 215 posts
Posted 09 October 2010 - 07:37 PM
Probably the best bet is i thnk is to get it to a rolling road tuner,probably wont take them long to sort it.
#8 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 09 October 2010 - 08:07 PM
thats your best bet,
my carb a HIF44 did this i couldnt go any faster than 35mph.
it was massively overfuelling, the engine was litterally drowning.
hope you win this one bud :D
#9 penfold38
penfold38
  • 215 posts
Posted 09 October 2010 - 08:22 PM
maggies_minder......How did you sort your problem in the end?
#10 maggies_minder
maggies_minder
  • 4,393 posts
Posted 09 October 2010 - 08:26 PM
i had the carb striped and rebuilt.
i no its an amatuer thing but make sure the carb dash pot has the right amount/correct type of oil.
#11 penfold38
penfold38
  • 215 posts
Posted 09 October 2010 - 08:34 PM
Thks for the info i may go for the hif38 and try that one, as the carb i have now was never the correct one anyway,then get it to a rolling road tuner.!
#12 Big_Adam
Big_Adam
  • 7,435 posts
Posted 09 October 2010 - 08:59 PM
Nooooooo!
Don't go HIF, they are a rubbish design that just makes road side repair a pain in the arse.
#13 blacktulip
blacktulip
  • 6,224 posts
Posted 10 October 2010 - 08:26 AM
Nooooooo!
what kind of repairs are you talking about? the hif carbs are nearly maintenance free. plus you dont get any fuel starvation on hard cornering.
as for the carb, have you got the right needle fitted?
#14 ukcooper
ukcooper
  • 1,625 posts
Posted 10 October 2010 - 11:04 AM
I'd try for a hif44 with a 1293cc if funds allow it would be worth the money then a rolling road session. If not then the hif38 and a rolling road session.
#15 morley
morley
  • 903 posts
Posted 10 October 2010 - 11:30 AM
Tried richening the mixture again?? :D
