Newly Rebuilt Engine Won’t Turn Over
#16
Posted 12 October 2010 - 06:52 PM
#17
Posted 12 October 2010 - 06:56 PM
Got it fitted in the standard location on the block for the stabiliser bar and the other end (because it’s a bit on the long side) to one of the new studs for the pedal box/clutch master cylinder.
#18
Posted 12 October 2010 - 07:05 PM
#19
Posted 12 October 2010 - 07:15 PM
#20
Posted 13 October 2010 - 05:35 PM
Edited by 1984mini25, 13 October 2010 - 05:35 PM.
#21
Posted 13 October 2010 - 06:00 PM
#22
Posted 13 October 2010 - 06:15 PM
It deffinantly sounds like a battery problem, try a jump pack or a set of jump leads on the battery and try cranking the engine over with the plugs out first of all to get the oil pressure up and then try and start it.
The plugs are out, but can't build any oil pressure as the starter motor WON'T even try to turn the engine over, let alone starting it.
#23
Posted 13 October 2010 - 06:22 PM
#24
Posted 13 October 2010 - 07:01 PM
I can’t can I, as they are of different types.tried the starter off the 25?
#25
Posted 13 October 2010 - 08:32 PM
#26
Posted 13 October 2010 - 08:49 PM
