Newly Rebuilt Engine Won’t Turn Over
Posted 07 October 2010 - 04:01 PM
All I get it the solenoid clicking and that’s about it, the starter does how ever work normally, if a bit lazy off the car.
So is it worth me fitting a new starter motor, it’s a pre engaged type. Or as the engine has been rebuilt with new rings/ hone and the original pistons refitted along with all the relevant bearings etc. Should I be looking at fitting an uprated one, or a more powerful one from another vehicle?
The engine does turn over by hand, but my guess is because of the new rings/hone it needs to be run for everything to bed in and loosen up.
Posted 07 October 2010 - 04:36 PM
Maybe try removing the spark plugs and turning it over with the starter motor then, to see if its easier. It's good practice to do that for a new engine anyway, to get oil pressure before it's started for real.
Edited by Mal_whitby, 07 October 2010 - 04:36 PM.
Posted 07 October 2010 - 04:40 PM
JJ
Posted 07 October 2010 - 04:41 PM
So trying to turn this one over might have just finished it off and I’ve already got the plugs out anyways.
Posted 07 October 2010 - 04:43 PM
Sounds daft, but is the battery fully charged?
I borrowed the fully charged one off the other mini.
Posted 07 October 2010 - 04:48 PM
Posted 07 October 2010 - 05:08 PM
Give the started motor a tap with a hammer, is the stater the right one for the flywheel? does the engine turn over by hand? Sounds like more of an electrical problem though, will be worth checking the battery works in the other mini but check the earth strap first.
I’d hope so, as the starter, flywheel, flywheel/clutch housing and gearbox all came off the same engine.
The engine does turn over by hand with no binding up, albeit if a bit on the tight side.
And the battery defiantly works in the other mini, but then the engine in that never takes much effort to turn over/started as its had 62k of use to free up.
The earths though I might go back over and check, I’ve already had a few issues with those with the other electrics (reworked loom) But the engine earth is currently a brand new 9” cable (I personally hate the braded ones as they fray after a short while) from one of the clutch cover bolts, so as close to the starter as possible, to one of the suds for the clutch master cylinder at the other end.
Posted 07 October 2010 - 05:20 PM
Posted 07 October 2010 - 07:30 PM
Posted 07 October 2010 - 08:33 PM
The engine should not be ' a bit tight' - it should turn over easily by hand with the plugs out!
Witch it does, with no tight spots, but it's not a free as the engine in the 25 thats done 62k.
Posted 07 October 2010 - 08:36 PM
Posted 12 October 2010 - 04:03 PM
Plus I’ve drained the battery over the last 3 days messing around with the electrics, but after swapping the battery back onto the 25, it fired up first try of the key without hesitation.
So if the battery is flat enough not to turn a starter on one engine, but quite happily turn over and start another, it can’t be the battery at fault.
But then I will take the 25 out for a good run to charge it back up before I end up with another dead battery to add to the collection.
So starters motors, am I stuck with a standard pre engaged or is then either a high torque alternative or a more powerful one from another vehicle that fits?
Edited by 1984mini25, 12 October 2010 - 04:04 PM.
Posted 12 October 2010 - 06:37 PM
What starter is on the other mini, can you swap it over and try it? or get another pre engaged from somewhere to try?
The solenoid throws the geared arm out when you apply the current and there is a big copper contact which pushes power to the motor when the gear is engaged. Its possible this is burnt out and not contcting properly, I have managed to clean them up tempararily but usually end up getting a new starter eventually.
Better to try another starter.
Posted 12 October 2010 - 06:44 PM
Posted 12 October 2010 - 06:49 PM
Don’t know about trying another starter from somewhere, the only real option I have it to buy another/new and try it. Or at least I don’t know anyone to borrow a working one from to try it.
But all I’ve been getting is the clicking of the solenoid firing and the battery/oil lights going out and that’s it.
