2.4 Ivtec Awd Mini Under A Standard Bellnose
100 replies to this topic
#31 charie t
charie t
  • 3,153 posts
Posted 30 November 2010 - 08:28 PM
the engine mounts are off a land rover 90, the arms that go from the axle to the body, these are axle ends, there are four.
Ah i had already tried the panard rod from a disco, but they were not beefy enough, and after seeing yours they looked perfic. Cheers :proud:
your frame looks very tidy
#32 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 23 December 2010 - 11:42 AM
Peaty - Any updates??
#33 blue blood
blue blood
  • 806 posts
Posted 23 December 2010 - 12:29 PM
This project looks amazing!
#34 peaty_34
peaty_34
  • 43 posts
Posted 24 December 2010 - 04:27 PM
hi all sorry for lack of updates relly busy at work got some new brakes for front and rear
some nice big discs for the front although i need to make then like the zcar front discs so they fit under the 13s and make my own front hubs too
the front brakes
and the matching rears
as son as christmas is over and the weather heats up get the hubs made, get the brakes fitted, get a cage in and it can stand on its wheels then it will all come together
#35 cptkirk
cptkirk
  • 1,799 posts
Posted 21 February 2011 - 11:28 AM
Peaty - Any Updates? been looking forward to hearing how this is going....
#36 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 28 February 2011 - 07:42 PM
+1
#37 peaty_34
peaty_34
  • 43 posts
Posted 01 March 2011 - 09:13 PM
hi all sorry for not updating , firstly your car looks the nuts cptkirk, soon as i saw it on the rack at the shop i knew it was yours lol, done a bit on the car, tacked a cage in (most inportant part) mounted rad, mounted the driif, brought a seat and got a pedal box on order, and cut the roof off.
still waiting on bits for front brakes
#38 cptkirk
cptkirk
  • 1,799 posts
Posted 02 March 2011 - 12:51 AM
Top Work, looking forward to the next update.
By the way - thanks for compliment about my car.
#39 peaty_34
peaty_34
  • 43 posts
Posted 02 March 2011 - 09:13 PM
done abit tonight made a tank out of card to get sizes and make sure it fits.
hen decided to make templates for the back
#40 cptkirk
cptkirk
  • 1,799 posts
Posted 04 March 2011 - 12:20 PM
Love it.
Whats your thinking on the air flow side of things for the rad?
Would you be best leaving the floor open and pushing air via the fans then ducting all the hot air out under the valance, that way you could keep the rear window as per the original (I am guessing looking at the templates that the rear window might get interfered with??)?
Are you thinking of a cold air feed from somewhere - maybe a side scoop?
If the ECU you are going to use is the original or Hondata then I can recommend a good interface bit of electrical equipment that I used on mine, it connects from the ECU to all the major bits and bobs like fuel pump, reverse light, ignition and so on, you do have to do some cutting and splicing but its not that bad - I did all mine myself with only a smidgin of electrical knowledge.
keep up the good work.
#41 Jayme 1275
Jayme 1275
  • 488 posts
Posted 04 March 2011 - 12:34 PM
looking well your making good progress.
i know the bulkhead custom but is the floor also?
#42 fordson
fordson
  • 203 posts
Posted 04 March 2011 - 12:49 PM
i have big respect for people who take on projects such as this and the cosworth mini. keep up the good work fella!! ;)
#43 peaty_34
peaty_34
  • 43 posts
Posted 04 March 2011 - 04:09 PM
thanks for the support, and yes m8 the floor is also custom
#44 kmol468
kmol468
  • 441 posts
Posted 04 March 2011 - 04:49 PM
Im loving the updates....
I always like seeing how people, who are tasked with a similar problem, come up with different ideas/ways of doing things. I love the boot mounted rad... it gives the car an even more crazy aspect to it, but as cptkirk says what plans have you got to ensure a good air flow?
Keep us all posted...
#45 peaty_34
peaty_34
  • 43 posts
Posted 05 March 2011 - 02:00 PM
the rad is a cosie rad withe two 12" fans i will have a scoop (Which will be made monday) that will scoop air from under the car into the rad, then out the rear window when stood the fans should kick in if all fails ill duct from 1/4 window, should get it cool enough as i am a ducter by trade LOL
