2.4 Ivtec Awd Mini Under A Standard Bellnose
100 replies to this topic
#16 daveeeeee
daveeeeee
  • 684 posts
Posted 08 October 2010 - 07:30 PM
This one's only going to be a mini on the outside ^^
#17 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 13 October 2010 - 12:28 PM
Great Project - subscribed
I am interested to see how your going to get the AWD to work.
Best of luck with it all, please keep up the progress pictures.
#18 peaty_34
peaty_34
  • 43 posts
Posted 13 October 2010 - 05:37 PM
hi the awd will work using the crv gearbox bolted to the k24 engine.
#19 cptkirk
cptkirk
  • 1,799 posts
Posted 13 October 2010 - 06:22 PM
@Peaty_34 -> Not meaning to be rude but I had figured that bit out (I have a bit of experience with Honda engines), I was meaning more how the whole setup is going to work, fitting the rear diff, driveshaft lengths, propshaft length, how you deal with gear ratios (as in OEM final drive and 13" wheels), overcoming the annoying way that the Honda AWD system switches from FWD to AWD, normally mid corner if your trying to give it some beans, fitting the coolant pipes in with the propshaft as you are running a rear radiator (ballsy move by the way).
If it all comes together it will be an very interesting package, I honestly cant wait to see the updates, along with the cosworth conversion I think is one of the more gutsy conversions, I applaud anyone with the kahunas to actually get their hands dirty and get something made that hasnt been done before...
Edited by cptkirk, 15 October 2010 - 12:52 PM.
#20 peaty_34
peaty_34
  • 43 posts
Posted 14 October 2010 - 02:23 PM
hi sorry it didnt mean to sound like that, the rear diff will be hung of the rollcage,the shafts will be honda to vauxhall, ill just cut and weld to start with so i can get the correct lenghts of the shafts. ill see what the final drive is like, you can but a final drive kit for a mini, superfast minis in america. i thought about making it permanent awd so lock the transfer box or something, ill look into it if its a problem.id like to put the coolant pipes down the tunnel but if it becomes a problem the can go inside.
thanks for all the comments, many heads is better than one, heres some pictures as promised not had a lot of time on her at min.
#21 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 14 October 2010 - 02:26 PM
loving this project! lots of very tidy fabrication going on! good to see something outside the normal mini box designs and conversions!
keep up the good work!
#22 cptkirk
cptkirk
  • 1,799 posts
Posted 15 October 2010 - 01:05 PM
You're quite right about many heads being better than one, sometimes I wished for a manual on how to build a Zcars kit or someone local to ask how they had done it but without them I learnt an absolute truck load along the way. There is always a need to ask others, you may have to ask many to get the answer you need, but you'll get there in the end....
I am not a Honda expert but if you have any questions please feel free to ask, I might be able to shed some light for you, after all the K24 is the same as the K20 only with a longer stroke, higher block and slightly different inlet manifold.
by the way you should have room to fit a Civic Jackson Racing Charger kit in there if you need more power - imagine that................
#23 peaty_34
peaty_34
  • 43 posts
Posted 15 October 2010 - 01:10 PM
Thanks for the support
#24 peaty_34
peaty_34
  • 43 posts
Posted 22 October 2010 - 06:01 PM
not been on for a while been working away, had a couple of ours on her today. Finished tacking the the cradle togetther, new frame looks 100x better than first.
ill make a start on the engine mountings again or the bottom arms tomorrow.
#25 EP3_Foolserrand
EP3_Foolserrand
    Starting My Mini Up
  • 1 posts
Posted 23 October 2010 - 05:33 PM
A most excellent project.
Coming from an EP3 owner currently running 314bhp with only a little boost :D I will be following this for sure.
K24/20 is what's know as a Frank Build, with the right breathing mods and a decent map using Kpro you will likely to see damn near 300bhp NA.
#26 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 23 October 2010 - 06:54 PM
Oh dear, oh dear! This is going to be the nuts!!
Keep the updates coming!!
#27 peaty_34
peaty_34
  • 43 posts
Posted 30 October 2010 - 01:50 PM
had a good couple of hours on her thins morning, fitted a bottom arm made a dummy strut and restricted the steering rack and cut arch out abit, it all works as it should, which is always a good thing.
#28 cptkirk
cptkirk
  • 1,799 posts
Posted 03 November 2010 - 10:41 AM
Beaut - top work
#29 charie t
charie t
  • 3,153 posts
Posted 21 November 2010 - 09:11 AM
hi peaty, just a quick question, where did you get your engine mounts from?
#30 peaty_34
peaty_34
  • 43 posts
Posted 30 November 2010 - 01:06 PM
Hi all sorry for not posting for a while been to the big USA, the engine mounts are of a land rover 90 the arms that go from the axel to the body these are axel ends thier is four.
