Any help would be much appreciated.
Evan.
![Posted Image](http://i847.photobucket.com/albums/ab38/EvanBrown_1977loudmini/041020106457.jpg)
![Posted Image](http://i847.photobucket.com/albums/ab38/EvanBrown_1977loudmini/041020106458.jpg)
![Posted Image](http://i847.photobucket.com/albums/ab38/EvanBrown_1977loudmini/041020106459.jpg)
![Posted Image](http://i847.photobucket.com/albums/ab38/EvanBrown_1977loudmini/041020106461.jpg)
Posted 04 October 2010 - 06:00 PM
Posted 04 October 2010 - 06:50 PM
Posted 04 October 2010 - 06:57 PM
Unless it's had a whack or two I'd be suprised if either were cracked- probably just casting marks. Maybe check the part numbers on both cases to see if they are the same, how clean the oil is is normally the best way to see how well it has been looked after in the past, in which case the 998 one may be the wiser choice- but without trying each you can't guarentee how good the syncros will be. Count the number of teeth on each crownwheel and pinion (tipex one tooth and count round) as they may be different ratios, then you can decide what ratio you would rather have depending on what you want the car to do.
Hope that helps!
TC
Posted 04 October 2010 - 06:59 PM
Posted 04 October 2010 - 07:05 PM
Posted 04 October 2010 - 07:09 PM
Posted 04 October 2010 - 07:10 PM
yip. go onto guess-works.co.uk (or maybe .com.. don't remember offhand!) and you can see the possibilities and variations.
Posted 04 October 2010 - 07:19 PM
Posted 04 October 2010 - 07:20 PM
Posted 04 October 2010 - 07:23 PM
Final drive ratio- just divide the number of teeth on the crownwheel by the number on the pinion, eg 60 on the cw and 20 on the pinion is 60/20=3 = 3:1.
Posted 04 October 2010 - 07:26 PM
Posted 04 October 2010 - 07:32 PM
if your box is from an "E" model, then it'll likely have a 2.9 FD, which will be too high. good for motorway speeds, but a bit too tall for town/backroads. You'd be better off looking for a 3.4 or 3.7, but it depends on what cam you are using aswell. you don't want to "fall off" the cam... which is basically when you change gear, to drop to such low revs that you are no longer in the peak characteristics. But then again, you don't want to go too much (3.7 *may* be too much, and anything above that) and you'll be changing gear every 3 seconds and be at 6000rpm at 65mph on the motorway, which will get very unfunny very quickly.
Posted 04 October 2010 - 08:08 PM
Posted 04 October 2010 - 08:25 PM
Posted 04 October 2010 - 08:31 PM
