Want A New Starter Motor.
8 replies to this topic
#1 mini-clive
mini-clive
  • 96 posts
Posted 04 October 2010 - 04:27 PM
I have an A+ MG Metro engine that only just starts and i'm wondering what sort of starter motor i have in there. Would it be inertia? if so what do i look for to replace?
Thank ye kindly
Edited by mini-clive, 04 October 2010 - 05:34 PM.
#2 mini-clive
mini-clive
  • 96 posts
Posted 04 October 2010 - 05:34 PM
Please! Anyone know about the A+ engine starter motor?
#3 mars red mike
mars red mike
  • 1,500 posts
Posted 04 October 2010 - 05:37 PM
Going by your avatar picture a H plate Mini should have a pre-engaged starter, same as the MG Metros (unless its a very early MG lump). Pre-engaged starters have the solenoid mounted on top of the starter whereas inertia starters have the solenoid mounted elsewhere, usually on the inner wing or sometimes mounted on the clutch cover.
#4 Spitz
Spitz
  • 1,716 posts
Posted 04 October 2010 - 05:42 PM
This one
http://minispares.co...a...3328&title=
#5 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 04 October 2010 - 05:44 PM
Does your car have a solenoid? It'll look something like this - http://www.minispare...ty=pb&pid=33370 This is usually positioned in the engine bay on the driver's side inner wing. There will be a thick wire from it to the starter motor. If you have one then it's an inertia starter - http://www.minispare...ty=pb&pid=35961
If the wire to the starter goes straight to the battery then it's pre-engaged strater motor - http://www.minispare...ty=pb&pid=33328
If you're still unsure post up a picture of your engine bay driver's side and we should be able to tell you.
hth
#6 ShoutforJoy
ShoutforJoy
  • 738 posts
Posted 04 October 2010 - 05:50 PM
Are you quite sure that it's your starter motor? They're quite expensive to replace so you really should be sure. It would be worth checking all of the connections to the battery, starter motor and solenoid (if you have one) before shelling out. Also check the battery and charging circuit if you can - lots of battery places will do this for free.
#7 mini-clive
mini-clive
  • 96 posts
Posted 04 October 2010 - 06:03 PM
It wasn't built with the 1275, it was built with a 998. Will it still be pre engaged?
#8 woodsy483
woodsy483
  • 182 posts
Posted 04 October 2010 - 06:16 PM
I've got a pre-engaged starter available that I was going to list
Let me know if your interested
#9 ShoutforJoy
ShoutforJoy
  • 738 posts
Posted 04 October 2010 - 06:22 PM
It's very likley but impossible to tell for sure without looking at it. Does your current starter have the extra smaller cylinder attached (where the wires go) as shown in woodsy438's last picture? This is only found on the pre-engaged ones, inertia ones do not have it.
