850 Wont Start.
14 replies to this topic
#1 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 01 October 2010 - 09:45 PM
Model: Morris 850
Year: 1961
my friends got a 1961 Morris Mini 850 and it wont start
its been stood for a while but hes put new pionts, plugs, leads And a battery oh and fuel
anyone got any ideas? it dose turn over just wont fire.
#2 1984mini25
1984mini25
  • 8,784 posts
Posted 01 October 2010 - 09:58 PM
Is it getting fuel?
Are the plugs wet/smell of fuel?
Is there a spark at the points while held open and the igniton on?
And is there a spark at the plugs?
#3 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 01 October 2010 - 10:08 PM
there's a spark at the pionts and at the plugs and he said its getting fuel to the carb.
could there be crap in the carb? stopping fuel flowing throw? like the brown stuff?
#4 Ethel
  • 25,919 posts
Posted 01 October 2010 - 10:47 PM
yes
Splash a little fuel into the mouth of the carb and see if it will try and run on that.
#5 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 02 October 2010 - 06:13 AM
Right
ill give it a try :( then and get back to you lot later
thank you.
#6 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 02 October 2010 - 04:16 PM
hey peoples
been to see the mini today and ive tryed everything to try get it to go and got nothing
turns over
got voltage to coil at 12 volts, sparks at plugs, fuel to carb even when a little bit down back of the carb.
still nothing any help please.
#7 Ben1400
Ben1400
  • 40 posts
  • Local Club: Plymouth MC South West MC
Posted 02 October 2010 - 06:09 PM
Have you tried a set of known good spark plugs?
Are the plugs that are fitted wet when you take them out shortly after trying to start it?
Have you checked the static ignition timing?
None of these? try warming the plugs with a blow lamp - gently, or if you haven't got one a ciggy lighter, whip em in & try again!
Need replies before we can go any further
Barry
#8 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 02 October 2010 - 06:14 PM
the dizzy body isnt bolted the engine but i did bolt it back on and lined it up with the bolt marks that were left when he took it off
and there brand new NGK plugs, and i tryed warming them and still got nothing
#9 Jacko-lah
Jacko-lah
  • 507 posts
  • Local Club: Derbyshire Classic Mini OC
Posted 03 October 2010 - 05:12 PM
Put the spark plugs in the oven for 20 mins.
#10 BLUE ITALIAN JOB
BLUE ITALIAN JOB
  • 204 posts
  • Local Club: thames valley
Posted 03 October 2010 - 06:08 PM
double check the HT leads are in the right place / order - may not be as the book says , check with the timing marks and cap off - get it to TDC and see where the rotor arm is pointing and if the points have just opened , if all is good the arm should be at the No 1 lead ....
#11 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 03 October 2010 - 06:27 PM
okay ill give it a shot but at this rate we're just going to toe it to the garage remove the engine and have gear box rebuild and then engine can have some new bits too
#12 mk1leg
mk1leg
  • 9,343 posts
Posted 03 October 2010 - 09:23 PM
Check that the dizzy is in the right place ie no:1 lead at approx 1-2 oclock and lead order 1-3-4-2 in anticlockwise direction............ :)
#13 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 04 October 2010 - 04:42 AM
right ill try that then :) cause it wants to go but its just not going :/
#14 Ben1400
Ben1400
  • 40 posts
Posted 04 October 2010 - 07:06 AM
Check the static timing in accordance with the workshop manual
Check the HT leads are in the correct firing order.
When you set the static timing ensure you follow the bit about the valves rocking to ensure you are timing the correct way and not 180 out. Check the rotor arm is pointing at No 1 cylinder, this will ensure you have the spark at the right time at the right plug!
HTH
Barry
#15 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 04 October 2010 - 06:41 PM
right i shall crack on with this when i see the car again what im guess at this rate will be soon :D thanks everyone
