My Mk1 Mini Rebuild
#91
Posted 04 January 2013 - 01:12 PM
How does the edge of the inner wing line up against the a post though? What part of the A post is it supposed to be welded to? Can't tell from looking at mine as it's in such a state with loads of old 'repairs' in the way.
#92
Posted 23 January 2013 - 09:47 AM
Good question :) Mine's the same. But, it looks to me like the trailing edge of the inner wing / flitch is spot welded to the 'step' in the A post - I will try get some more pictures to explain. I have seen somewhere that there is a gap between A panels and pillar which would have been filled with some foam??! Argh.How does the edge of the inner wing line up against the a post though? What part of the A post is it supposed to be welded to? Can't tell from looking at mine as it's in such a state with loads of old 'repairs' in the way.
#93
Posted 23 January 2013 - 09:49 AM
#94
Posted 01 February 2013 - 08:23 PM
I drew along the join lines from the interior where possible and got things clamped up. The cleco pins are invaluable for clamping the parcel shelf to the inner wing. First time I've used these.
I clamped some angle iron along the shock mounts to clamp things up nicely.
Put a couple of plug welds in:
Lastly, this is the 'natural' join between the inner wing and door pillar. Are these supposed to meet and be welded together? I've given up deliberating. I know the inner wing is in the right place so it's probably the A post which is out...?
Should I attempt to pull these together up the line of the A post? Or rely on spotting the outer and Inner A panels together to provide support?
I reckon I could put self tappers through to clamp together, just not sure if this is right? Any suggestions?
Mike
#95
Posted 04 February 2013 - 10:35 PM
Its difficult to explain but the upper section of the inner wing/flitch was spot welded to the inner step of the A post, then lower down where the A post turns into the door step theres a raised step in the inner wing, that was spot welded to the lower part of the outer A panel/ door step. Hope that makes sense and reads with the pics.
Keep up the good work
Ollie
#96
Posted 05 February 2013 - 07:29 AM
photo hosting sites
#97
Posted 05 February 2013 - 08:49 AM
Oh well, it's progress I suppose...
Mike
#98
Posted 05 February 2013 - 05:28 PM
#99
Posted 05 February 2013 - 05:39 PM
Hi Mike, I have a couple of pictures of my mkII A post (built 1967) as I was picking it apart that might be of use to you. I'm pretty sure it had never been apart before so original and rusty and I presume the same as your mk I. The return section of inner wing tucks in tight behind the A post and was spot welded together.
P1050239.JPG 34.48K 48 downloads
P1050248.JPG 29.13K 41 downloads
P1050242.JPG 32.01K 36 downloads
Ollie
May i ask were you got the doorstep panel in the middle photo you posted ?,as i need that exact one which goes up alot further than the usual doorstep panels.
Regards
Clifford
#100
Posted 05 February 2013 - 05:41 PM
keep at it.
#101
Posted 05 February 2013 - 05:48 PM
Well I guess the car is a bit of an odd shape - if you ever saw the state of it to start with it was patchwork hell. With the doors and A panel in place along the current A post line everything fits and looks right, although the door-to-A post gap is too large but not beyond being adjusted. Weird.
Oh well, the car is an enigma and hardly an unadulterated original. It is what it is and I shall do a better job than the previous restorer. All good practice for the next 2 :)
Thanks again - Ollie your mk2 build is amazing.
#102
Posted 05 February 2013 - 05:49 PM
Clifford - that looks like the m-machine one, same as I have. Doesn't look like it does in the parts catalogue, there is loads of well pressed material on either side vertical. A good part imho.
Hi Mike, I have a couple of pictures of my mkII A post (built 1967) as I was picking it apart that might be of use to you. I'm pretty sure it had never been apart before so original and rusty and I presume the same as your mk I. The return section of inner wing tucks in tight behind the A post and was spot welded together.P1050239.JPG 34.48K 48 downloads
Ollie
Regards
Clifford
Cheers - Mike
#103
Posted 05 February 2013 - 05:52 PM
Ollie
Regards Clifford
Cheers - Mike
Thank you shall be back on the phone to m-machine in a flash ;)
Thank you.
#104
Posted 05 February 2013 - 08:07 PM
I've a 71 clubman with an MED 1380 waiting under a sheet for after myself, not in bad condition though considering the body is mostly original.
Clifford, Mike is right, the door steps are M-Machine, I found it to be a pretty good panel as well. I would imagine its a fairly difficult panel to make properly as it has a slight taper front to back on the door step itself and a slight curve that follows the sill line looking down the body.
The M-Machine door step repair panel looks like this, its the lower one on the parcel shelf, the one above is a section I was making but gave up on as I really needed curved section at either end as well so bought the M-Machine one.
Hope you don't mind my posting a picture on your build thread Mike.
Ollie
#105
Posted 05 February 2013 - 08:27 PM
Cliff
