What kit to get?
#61
Posted 10 December 2005 - 10:47 PM
#62
Posted 10 December 2005 - 11:14 PM
I use 8awg cable on mine but the amp is on a boot board so the cable needs to be quite flexible (had 4awg and it was a pain in the ass).
Oh and it will sound a hell of a lot better than the standard lol
#63
Posted 10 December 2005 - 11:17 PM
Will my battery/alternator handle all this OK?
I cant seem to find any wiring kits on CAD =( can anyone point me in the right direction?
All the best
Tom
#64
Posted 11 December 2005 - 11:04 AM
A 55amp mg metro alternator would just do although a 70amp would be better, as for the battery just buy the biggest that will fit in the hole (you are looking for the one with the highest cranking amps CCA). A peugeot 306 diesel battery will fit.
As for cable you need 1 live and 1 earth per amp, as well as 2 sets of phono leads (from headunit to amp), you also need to run a trigger from the headunit to the amps.
Then you need speaker cable from amps to speakers and in-line fuses for the + side of the amp (as near to the battery as possible).
You also may need terminals to fit on the power and speaker leads depending on how they are connected on amp and speaker.
8 awg cable
speaker cable
fuse holder
Fuses
phono leads (made by stinger)
#65
Posted 11 December 2005 - 07:31 PM
So I need a live (both fused as close to the battery as poss) wire and an earth from each amp, where is the best place to earth it in the rear of the mini?
Is the 8 awg cable for the subs? (escuse my noobishness).
Is there somewhere I can find some explaination of how its all wired? all seems a bit confusing to me : / I have a friend who has installed alot of I.C.E and seems to know what he is on about, but I need to be sure before he go's messin with my car!
Appreciate all the help you guys have given me.
Tom
#66
Posted 11 December 2005 - 08:01 PM
All amps have this otherwise the amp would be on permanently.
8awg wire is the thickness of the power and earth cable
just connect the eath to the neg on the battery, thats what i have done.
#67
Posted 11 December 2005 - 08:59 PM
All the best
Tom
#70
Posted 11 December 2005 - 09:21 PM
#71
Posted 11 December 2005 - 09:25 PM
#72
Posted 11 December 2005 - 09:31 PM
Tom
#73
Posted 11 December 2005 - 09:37 PM
http://www.caraudiod...a18a3319df72d70
#74
Posted 12 December 2005 - 07:41 PM
I was thinking it would be cool to have the cooper laurel around each sub sewn in, but I cant think of what material to Use, and where to get it sewn, I think it would be large enough to look good if time is spent on it.
Maybe black bass box carpet (think kind) and thin leather laurel.
Thanks again for all the help lads.
Tom
#75
Posted 15 December 2005 - 11:38 PM
All the best
Tom
Bing (1)
