Bought A 1380 Engine Today
#16
Posted 25 September 2010 - 09:18 PM
Many thanks.
#17
Posted 25 September 2010 - 09:20 PM
#18
Posted 25 September 2010 - 09:23 PM
one thing concerns me, the marks on the conrods, in one of the pictures the conrod has 3 dots, and the end cap has 4, indicating it is the wrong one for that rod, they are a machined pair, and must be assembled as a matching pair.
I thought that as well!!
#19
Posted 25 September 2010 - 09:25 PM
#20
Posted 25 September 2010 - 09:26 PM
#21
Double check all the cap's are matched upto the correct rod, looks to me like the pistons have been took at sometime and put back in willy nilly as 3 and 4 are in the middle of the block.
#22
Posted 25 September 2010 - 09:31 PM
Was just about to comment on the cap's now I've woke up after some coffee.
I don't mean to sound stupid but how can you tell which pistons goes in which bore. I'm new to this part so any help is very much appreciated.
Evan.
Edited by 1977 Loud_Mini, 25 September 2010 - 09:32 PM.
#23
Posted 25 September 2010 - 09:37 PM
One would imagine this chap might of done the same when tipexing the rod's. Ideally with the engine being run before, the same piston should be fitted back into the same bore unless re-ringing/honing the block is carried out.
#24
Posted 25 September 2010 - 09:44 PM
When I stamp rods to remove them from a block or to have piston's fitted, I have the numbers facing the front of the block with No.1 being the radiator end.
Well i'll check it out tomorrow and post on here along with some more pics. The bores look as if they haven't been run at all since the new rings were installed and honing marks are very visible.
#25
Posted 25 September 2010 - 09:47 PM
#26
Posted 25 September 2010 - 09:52 PM
#27
Posted 25 September 2010 - 10:02 PM
I'd imagine if you got the block out with it at TDC and tried to rock the crank with your hands it would be rather stiff, or not even move, this would show that the cap's are wrong.
You can tell with a good eye on the side of a rod's thrust if the cap's are the correct ones.
#28
Posted 25 September 2010 - 10:46 PM
#29
Posted 26 September 2010 - 01:35 AM
#30
Posted 26 September 2010 - 09:17 AM
You'll need a decent big valve head, ideally stage 3-4 at least, and some decent fuelling, like a 45DCOE or twin HS4's.
Without these, you'll have poor low end power due to the cam you've got, and poor top end power due to the head/fuelling.
Depending on budget it'd be nice to have the crank worked a tad whilst it's apart, wedging a crank greatly reduces the rotating mass. With such a revvy cam, it's almost a shame to mate it to a heavy standard bottom end.
I've got a 296 scatter in my 1380 currently, with 1.5:1 roller rockers and an MED roadcomp head, it makes 115 bhp and 100lbft, and ideally could do with a better head.
To drive, it's a great engine for a weekend car, although I wouldn't fancy using it every day, it needs to be above 3000rpm the entire time, below this it simply won't drive at all, and stutters badly. Slark said this was just the nature of the cam and webber conbination.
Over 3000rpm though, it's amazing, bags of power, with a great spread of torque, and it pulls solidly to 8000rpm, although I've limited mine at 7600 to keep it safe long term.
Get it built up with a decent box and you'll have a lovely engine
