Bought A 1380 Engine Today
42 replies to this topic
#1 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 25 September 2010 - 08:24 PM
Hi all, picked up a 1380cc engine today. The work done so far is. New cam followers, 296 kent camshaft scatter pattern, new vernier timing kit, new piston rings, nearly new Powermax pistons 73.5mm, crank reground and new big end and main shells, new oil pump and valve, i think it has a centre main strap but not 100%.
Are the conrod standard bolts or are they stronger versions. Also think it may have had an electric fuel pump at some point as the mechanical fuel pump is blanked off, is the crank a standard 1275 as i have pictured the markings. Also found some interesting marking on the block face, i'm guessing its the offsets that the bores have been bored out by.
Let me know what you think.
Evan.
#2 danrock101
danrock101
  • 2,478 posts
Posted 25 September 2010 - 08:32 PM
it's got a centre main strap, crank is standard, balanced from what I can tell
#3 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 25 September 2010 - 08:37 PM
Thanks for the help, that's good to here about the centre main strap. How do you know if the crank is balanced then?
#4 scsracing
scsracing
  • 276 posts
Posted 25 September 2010 - 08:38 PM
I was watching that one on ebay,i bought the other engine that guy was selling :mrcool:
#5 danrock101
danrock101
  • 2,478 posts
There's parts of the crank that's been removed
#6 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 25 September 2010 - 08:40 PM
Oh rite, the person i bought this off said they had another engine they just sold. What spec was it or was it standard?
#7 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 25 September 2010 - 08:42 PM
Ah let's hope it has been balanced then or thats a job i will need to have done.
Edited by 1977 Loud_Mini, 25 September 2010 - 08:42 PM.
#8 scsracing
scsracing
  • 276 posts
Posted 25 September 2010 - 08:46 PM
This was the engine
http://cgi.ebay.co.u...3#ht_692wt_1137
Just going to get one of these for it too soon.
http://www.swiftune....duplex-kit.aspx
Very handy that most of the work has already been done to it ;)
#9 Southy
Southy
  • 1,579 posts
  • Local Club: Oldham and Distrcit Mini Club
Posted 25 September 2010 - 08:50 PM
As said the crank is standard, its an early 1275 crank without the filleted radius'. Doesn't look to be balanced as far as I can tell, the bits missing are done as std when cast.
Con rod bolts are std A+ ones. Centre strap is fitted to the block, and looks like a fairly thick one aswell.
Block looks like it hasn't been skimmed at any time due to seeing the B stamped into it still.
#10 danrock101
danrock101
  • 2,478 posts
Posted 25 September 2010 - 08:53 PM
Just read the listing for your 1380 and it does say it's been balanced. You can tell it's has metal machine away from it in the past, if you look in the second picture from the bottom you can see a bit taken away and has x stamped in it.
#11 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 25 September 2010 - 08:54 PM
Thanks for the info, would i need to get the crank balanced then? if so do i need it taken out with pistons, conrods and flywheel attached to get the whole lot balanced?
Also do the conrods need special sockets to torque them up as i need to check they're tightened correctly.
#12 Southy
Southy
  • 1,579 posts
Posted 25 September 2010 - 09:01 PM
It wouldn't do any harm to get it balance up no, I would recommend getting all the rotating assembley balanced up, especially if your planning on giving it some stick. A good machine shop will balance the crank on its on and then add the flywheel and then balance that, that way each component is individually balanced.
The AE 20659's are fairly spot on for weighing the same, if the conrods are the original complete set out of the engine then they will be fairly close, not out by more than a couple of grams at most.
No special socket for the conrod bolts, just a 1/2inch multi hex socket is required.
#13 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 25 September 2010 - 09:02 PM
This was the engine
Yeah your engine and mine has had a fair bit of work and money spent on them. I did see yours on ebay but thought the 1380 would be more suited to what i'm after. Nice twin carbs you got though :cry:
By the looks of it the vernier timing kit i have looks like the swiftune one so thats a bonus.
#14 danrock101
danrock101
  • 2,478 posts
It will be worth checking crank endfloat, I used a normal socket on my rods, check the straps are tourqed up too while you're at it, don't know the settings though, 65lb/ft I think it is, but make sure you double check this with somone who knows what they're talking about, no idea on the co-rods
#15 Southy
Southy
  • 1,579 posts
Posted 25 September 2010 - 09:12 PM
35lb/ft for con rod bolt
