Head Identification
6 replies to this topic
#1 Kaison
Kaison
  • 124 posts
Posted 25 September 2010 - 09:37 AM
Model: Rover Mini Sprite 1275
Year: 1992
Well, the previous owner told me that the car has a metro head which he also said is the equivilent to a stage 2 head?
Just wanted to know how I can check that and also how I can identify what heads they are for future reference.
Any non-standard parts that might be involved with the problem? Apparently it's got a metro head.
It has a fletcher lcb and that's all you need to know :P
Edited by Kaison, 25 September 2010 - 11:54 AM.
#2 Asphalt
Asphalt
  • 2,173 posts
Posted 25 September 2010 - 11:17 AM
If you take off the rocker cover, there's a number on the head. Probably 12G940, which is a 1275cc head.
The thing is: about any 1275cc head that's not of a Cooper S Mk1/Mk2 has this very same number. And there are quite a lot of differences between those heads! The most obvious difference is between A and A+ (1980 onwards) heads:
The top head is a A, the bottom one is a A+ head:
Metros all got A+ heads. And then there are two different A+ Metro heads: smal and big valve heads. Smal = 33mm inlet valves, big = 35mm inlet valves. To check this, youneed to take off the head and measure a valve.
The next important point is: there is no such thing as a 'Stage 2' head!!! What tuner A sells as 'Stage 2'is another guys 'Stage 7.5' and so on... There's NO fast rule of what a 'Stage 2' head is... It's a bit of a very useless information. So the seller might be right or not - since there's no fast rule... Tricky, hey? :P
Head Casting numbers:
2A628 - 26.162/25.4 - 24,5 - 848, 998, 948 Sprite
2A609 - n/a - n/a - Smalbore closed chamber
2A629 - 26.162/25.4 - 24,5 - 948, A35, A40 und 1098 Morris Minor (open chamber?)
12A1456 - 26.162/25.4 - 24,5 - 848, 998, 948 Sprite
12A1458 - 26.162/25.4 - 24,5 - späte 848, 998
CAM4810 - 26.162/25.4 - 25,5 - 998 A+ (unleaded from 1988 onwards)
12G202 - 29.464//25.4 - 26,1 - Cooper 997, 1100
12G206 - 30.988/25.4 - 28,3 - Cooper 998, MG1100
12G295 - 30.988/25.4 - 28,3 - Cooper 998, MG1100
12A185* - n/a - n/a - Smalbore, similar 12G206 (pos. Formula Junior)
AEA626 - n/a - n/a - Formula Junior & Formula 3, 'S' Type (large bore, open chamber), f. XPS engine
AEG305 - n/a - n/a - Formel 3, XPS engine
AEG136 - 35.56/30.988 - 21,4 - Cooper S MkI/MkII
12G940** - 33.274/29.464 - 21,4 - 1300, 1275GT, plus A+ incl. Turbo
12G940** - 35.56/29.464 - 21,4 - MG1300, 1300GT, Cooper S MkIII (MkIIIS stamped 12G1805) & MG Metro (A+)
12G939 - n/a - 21,4(?) - 1275cc w/ Emission Control System, Healey Sprite MkIV, MG Midget MkIII, Austin America
12G1316 - n/a - n/a - 1275cc w/ Emission Control System, 1275LS, 1275 Moke (Australia)
12G940 + Stamping 12G938 - 33.274/29.464 - 21,4 - Morris 1100S (1275cc!) and 1300 Automatic (Australia)
(LDF105800 - 33.274/29.464 - 21,4 - MPI) - not confirmed yet!
Edited by Asphalt, 25 September 2010 - 11:18 AM.
#3 Kaison
Kaison
  • 124 posts
Posted 27 September 2010 - 01:27 PM
Thank you - that's VERY helpful!
By your picture and detail, it's an A+ head small valve head - 33mm
I just can't read the casting number! I assume it's the "blob" on the far left of the head in the picture.
Any other way of reading this?
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 September 2010 - 01:33 PM
The casting number is between 4 and 5 pushrod holes
#5 Kaison
Kaison
  • 124 posts
Posted 27 September 2010 - 02:16 PM
Okay - I'm a little worried. . . it's be ground off.
All I can see is 12**4* - That might not be correct but that's all I can make out. . .
Does this mean it's stolen or could it just be where it's been skimmed?
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 27 September 2010 - 02:27 PM
12G940 = 1275 head
Theres no engine id numbers on the heads, so you wouldnt expect the number to be destroyed if its been stolen etc.
#7 ukcooper
ukcooper
  • 1,625 posts
Posted 06 May 2017 - 05:47 PM
