Wiring 6x9's To Amp/sub Problem
Posted 23 September 2010 - 03:38 PM
Any ideas what ive done wrong as I know the speakers work??
or would it be easier to wire the 6x9's straight out of the Head unit??
Posted 23 September 2010 - 03:43 PM
if you run your 6x9s you may also lose power to your sub and not give it enough wattage therefore slowly kill your sub woofer
if the rms is around 50 or below wack them on your headunit
Posted 23 September 2010 - 03:49 PM
They will sounds better off your amp but headunit sounds the best bet,
yer will defo sound better through the amp..... but if i cant get them to work will have to be through the HU
oh thats not good
I dont know what the RMS is unfortunatley dosnt say on the bottom lol :/ and i dont have the box any more...... but there 450 watts if that helps
Edited by Grimson2452, 23 September 2010 - 03:49 PM.
Posted 27 September 2010 - 12:05 PM
oh thats not good
I dont know what the RMS is unfortunatley dosnt say on the bottom lol :/ and i dont have the box any more...... but there 450 watts if that helpslol
if there a max of 450watts i would wack a minimum of 150wattsrms into them that means you would have to use an amp!!
Posted 27 September 2010 - 01:06 PM
but by the sounds of things you've split a set of RCA's and have some how connected the 6x9 strate to the spit connection... with no sort of amplification....
...what is between the RCA's and the 6x9s?
