Outer Cv Joint Removal
15 replies to this topic
#16 mikey72
mikey72
  • 321 posts
Posted 19 September 2010 - 06:41 PM
I use these now
http://cgi.ebay.co.u...=item27b2b71979
and buy another boot if you are doing both.
Slide on fairly easily, (good bit of pushing needed, the hardest part is getting the cone off later, on cars where the driveshaft isn't fastened into the gearbox, it's easy to pull the driveshaft out if you're not careful) and I've had no problems with ones I've fitted 18 months ago.
