Wing Mirror Removal`
Posted 18 September 2010 - 04:01 PM
I took the door card out but cant figure out how to get the wing mirrors off! any help would be appreciate as I am a bit of a mini dunce!
Tilly xxx
Posted 18 September 2010 - 04:14 PM
I bought new wing mirrors for my mini because mine fell out!!! anywhoo I wanted to go for a change so I bought some different ones.
Tilly xxx
on your actual wing mirror underneith there will be a triangle shape cap you just need to pop this of with a flat screwdriver and underneith there is 2 machine screws which hold the mirror on. hope this helps. you do not have to remove the door card
When i did it the 1st screw needed plenty of WD40 before it moved anywhere.
Once you have got it off its pretty obvious how to get the new ones on as it is the reverse.
Posted 18 September 2010 - 05:24 PM
Posted 18 September 2010 - 08:09 PM
(which will then cause you a big headache to try and rectify)
Takes less than a minute if you have the right tools though! A Rivnut setter is a very useful tool to have.
Posted 19 September 2010 - 02:57 PM
thanks again I'll give it a go!
xx
