K Series Conversion
Posted 18 September 2010 - 10:59 AM
Posted 07 December 2010 - 03:48 PM
Where are you getting the 1400 turbo from?I'm thinking about converting to a 1400 turbo. Has anyone done it and is there anything to look out for?
Posted 07 December 2010 - 05:26 PM
http://www.16vminicl...read.php?t=8625
Posted 07 December 2010 - 05:32 PM
They did the T Series what is the turbo version and if i remember right they where 1600+
the MG Rover Forum for best information on these engines, ive got alot of stuff about the k series also knowing that you got have a lot of piston crank con rod, block, cooling system & head work done to run a turbo on it, its so much easier to get a T Series and use that with in the mini
Posted 07 December 2010 - 05:36 PM
there is a lot of info on what you can and can't modify body wise on the Association of Car Enthusiasts web site linked below
Posted 07 December 2010 - 07:24 PM
hes getting the 1400 turbo off of evo's build.
that engine has had about 6 years worth of trials. but, it was a proper toy.. theres a few youtube vids with 1/4's and one short road vid.
Posted 08 December 2010 - 08:53 PM
T16 lol but it was a 2ltr, but as you say the K was never turbo'd as standard, so i didn't know if he had found somebody developing one off the shelfThey didn't do a K Series Turbo
Posted 08 December 2010 - 08:56 PM
Edited by .998TANGO., 08 December 2010 - 09:04 PM.
Posted 08 December 2010 - 09:10 PM
the 1.4 k series as the engine matt is intending to fitwhat about a 1.8 turbo out of a mg zt?. they look like they're the k-series.
Posted 08 December 2010 - 09:22 PM
Dont go for the 1.8, the 1.4 is pretty bombproof with a few simple mods, its all in the link.
http://www.16vminicl...read.php?t=3208
Posted 08 December 2010 - 09:55 PM
Posted 08 December 2010 - 09:59 PM
The amount of work involed in turboing a K series you need
Uprated crank (harded & cross drilled will help)
Uprated Conrods
Loads of head work (valves, guides, followers)
Piston upgrade
Oil Pump upgrade
Head Gasket Upgrade
Disel Gear box (standered wouldn't handle the turbo)
and they didn't turbo the K seires
it was the T Seires they Turbo'd Hense the "T" series engine
Posted 08 December 2010 - 10:13 PM
read my link.
Posted 09 December 2010 - 12:38 AM
Steve they did turbo the 1.8 K seriesand they didn't turbo the K seires
http://www.mgownersc...mg-zt-zt-t.html
As for the amount of work involved all depends how much boost you want to run
Posted 09 December 2010 - 07:27 PM
read 16v mini forums. and rovertec.
