Kad Electric Water Pump
24 replies to this topic
#1 miniobsessed
miniobsessed
  • 211 posts
Posted 15 September 2010 - 02:15 AM
Hi Guys.
Has anybody had any experience with the KAD Electric Water Pump?
Does it flow enough water to keep a modified engine cool? How does the flow rate and pressure compare to the standard cast impellor pump?
Not to knock KAD, because I think they do great work, but it looks a bit like a bilge or water feature pump with a couple of alloy adaptors and I'm wondering if it's actually up to the job...
#2 MintecMiniSpares
MintecMiniSpares
  • 125 posts
Posted 15 September 2010 - 07:34 AM
Not sure about the Kad pump but i've had good results with the Davies Craig pumps and I know they're widely used.
www.daviescraig.com.au
#3 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 09 September 2020 - 10:14 PM
Holly Thread Resurrection Batman! I was about to post something similar when doing a search I found this, so rather than start a new thread I'll update here.
The current KAD electric water pump they are selling is a Bosch 0392020034 pump. Yours' for about £70 online. Who knows why KAD charge £240 for it! Specs for this pump is 850L/Hr or 85L/min. I'm told standard water pump is 80L/min.
The 'Craig David' VFD/PWM pump controller is useful way of increasing pumping speed based in engine temp. Low temps, low flow. High temps, higher flows.
Edited by Curley, 10 September 2020 - 03:55 PM.
#4 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 10 September 2020 - 06:31 AM
I wonder how much energy the standard water pump uses compared to (is it measurable) how much the elec one uses? I've often thought about changing to an elec pump even though my mini is a road use only. If only to save a little power from the engine and hopefully a bit more control on temp when standing in traffic. Does it make it "safer" for the engine when it's warming up in that there will be a very slow movement of coolant through the engine instead of stagnant coolant waiting for the thermostat to open and then the possibility of hot spots being created? Maybe this is irrelevant in a small engine?
#5 PoolGuy
PoolGuy
  • 848 posts
Posted 10 September 2020 - 07:18 AM
It certainly looks the same as the pump that Amazon sell for £55. There are a few advantages of electric pumps aside from any differences is power consumption, they don’t cavitate, they can run after the engine is switched off, they can run at variable speeds. They’re particularly useful in race environments, we started using them in Miglias in 1990, that was a motorhome pump used for supplying the sink and shower.
#6 sonscar
sonscar
  • 3,004 posts
Posted 10 September 2020 - 07:41 AM
Is the power used driving the water pump then used to drive the alternator?Steve..
#7 johnR
johnR
  • 2,298 posts
Posted 10 September 2020 - 08:24 AM
Good question
#8 GraemeC
GraemeC
  • 7,438 posts
Posted 10 September 2020 - 08:30 AM
The alternator would still be driven off the crank, just with a shorter belt.
I think you'll only see any real power saving advantage from an electric water pump when a front mounted rad is used.
#9 mini13
mini13
  • 3,810 posts
Posted 10 September 2020 - 08:34 AM
Yes, but allegedly the mechanical pump will use a fair bit of excess power at high revs compared to a electric pump. i seem to remember a figure of a couple of horseower for the mechanical pump, and 1/2 hp for an electric pump.
#10 sonscar
sonscar
  • 3,004 posts
Posted 10 September 2020 - 10:59 AM
Like in the good old days when they guessed how much power the water pump,alternator oil pump and anything else they could think of then added this to the quoted power.Today's problem is "I read it on the internet so it must be true", Steve..
#11 skoughi
skoughi
  • 1,199 posts
Posted 10 September 2020 - 12:18 PM
Do you use the thermostat with an electric pump or is there no need as the speed of the pump is controlled by the engine and/or coolant temp?
#12 sonscar
sonscar
  • 3,004 posts
Posted 10 September 2020 - 12:36 PM
I understand you remove the stat and restrict the hole and the pump controller does the rest.Automotive quality parts throughout I would think as failure is not really an option.Mainstream manufacturors are using the tech so it has some merits if designed as a package,but as a retrofit?I personally will sacrifice a potential few HP.Steve..
#13 stoneface
stoneface
  • 370 posts
Posted 10 September 2020 - 02:34 PM
I use the Davies Craig on my engine.
No thermostat needed. But as above a restriction is needed. I use a thermostat with the inner removed as the restriction.
#14 PoolGuy
PoolGuy
  • 848 posts
Posted 10 September 2020 - 02:45 PM
In the back of my mind you should also run without a bypass fitted, but that's probably more to do with the stat being removed?
#15 burchy35
burchy35
  • 114 posts
Posted 10 September 2020 - 02:52 PM
I also use a Craig Davis pump with a front mounted radiator, when its cold weather I have to put a thermostat in because it wont get up to temperature. And I have a controller fitted which slows the pump right down to get the engine up to temperature quicker.
The car is a 1460 turbo track car which does generate plenty of heat. Water cools the turbo which also acts as a bypass. In warmer conditions it's perfect with the thermostat removed and a sleeve in place.
