Clubby Estate
658 replies to this topic
#316 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 13 November 2011 - 10:18 AM
Reverse rims and cooper s disks with no arch modifications are tight when turning tho, you can see how low mine is and it touches occasionally nothing bad tho!
that's how ill be running mine with spaced drums at the rear
Danny
My rear wheels look so odd close up! I don't have adjuster brackets so there is loads of positive camber and toe in is mental! Now it's lowered n spaced it looks better, I'm still not happy though!
How hard is it to fit the brackets when the subframe is in situ?
i haven't got a ue to be honest never changed them yet and any Piccys of the rear wheels and how they sit in the arch ect
Danny
#317 tedmcedd
tedmcedd
  • 2,751 posts
Posted 13 November 2011 - 03:58 PM
looking great man! really coming along!
#318 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 13 November 2011 - 06:02 PM
thanks :) i can see the light at the end of the tunnel lol
#319 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 17 November 2011 - 04:56 PM
got a bit more done today the heelboard was only tacked in place so today full welded it in on one side and will do other side when i roll her over the other way and i also test fitted my m-machine rear bins and fitted ok need a but of work to make fit but nothink i cant do also welded the flitch to the door bit where the hidges go i didnt weld this bit on incase the strenthing panel inbetween the post had rotted away so waiting incase it needed replacing i also had to make a few mods today to the floor as it woudnt fit properly against the heel board as it was slightly to small so made a slit and made it fit them filled the slit with weld now all fitting perfectly :D
im quessing these weld marks on the inside of the floor from welding the sill on is a good sign ???
flitch bit welded properly
test fitted the rear bin
sills before grinding down
and after grinding the welds down
:( boot floor needs work
rear hellboard welded
and how shes finshed of today
all the black stuff on the floor is oil and my boss but a oil filter in the car and it fell over
Edited by mini danny, 17 November 2011 - 04:57 PM.
#320 danny1
danny1
    In the navy you can sail 7 peas
  • 1,321 posts
  • Local Club: bumpstart
Posted 17 November 2011 - 05:03 PM
is that a fiat 500 in the back ground?
#321 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
yep sure is
#322 danny1
danny1
  • 1,321 posts
Posted 17 November 2011 - 05:17 PM
there becoming a very rare find these days, very jelious
#323 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 17 November 2011 - 05:50 PM
the block who owns it has 6 of them lol
#324 danny1
danny1
  • 1,321 posts
Posted 17 November 2011 - 06:17 PM
what!
i want one aha
#325 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 17 November 2011 - 08:43 PM
I woundnt lol there all bodged and full of filler
Danny
#326 grahama
grahama
  • 2,442 posts
Posted 17 November 2011 - 09:44 PM
Looking good, penetration looks good on the sill welding and look great when ground down. I too love the old fiat 500s, would like one too lol !!
Graham
#327 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 18 November 2011 - 12:08 AM
Graham
many thanks for the comments make me have more motivation and ya ild like one to the bloke who own the one in pic has more classic cars then anyone I've ever seen
Danny
#328 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 18 November 2011 - 05:28 PM
done some more today not much as was busy all over the place today i managed to remove the rear subframe mounting panel that was very very very past it was full of filler and weld not good once removed i relised one side was missin the floor lol had no metel so had to finish for the day as was gonna make my own repair panel and found more filler and rust on the rear
heres the pics
before i removed it as you can see loads of weld on it
took the rear corner valance off to give me more hand room to break the weld
subframe panel again full of weld
removed the top bit and no floor :o
had to pick a car up for the boss and found this an old couple own it
finaly got the rest off and was surprised that it was rust free in the middle of the boot floor
#329 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
only noticed today that this was wavey and thought ild grind it back and found that it was made of filler and seem sealer and rust :(
need to make a repair panel for here
and how she sits now
all comments welcome
thanks danny
#330 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 18 November 2011 - 05:56 PM
Looking good yet again! and that pickup is very nice!
